PLASMICS
Started by evolvingape, August 21, 2011, 11:22:46 PM
evolvingape
Hi Everyone,
Ultrasonic Atomisers will allow creation of a fine water vapor in the range 0 - 10 microns, similar to steam. This is an option for venturi injection into a Plasma Injector by piggy backing one of the other pressurised gas flows in the priming cycle.
Here is a youtube video showing vapor formation in slow motion, very cool  ;D
http://www.youtube.com/watch?v=rN-OcMSwS2I
Here are some off the shelf ultrasonic atomisers with usefull technical sheets at a reasonable price :)
http://uk.farnell.com/prowave/m2313500/transducer-atomiser-135khz/dp/1774944?Ntt=m2313500
http://www.farnell.com/datasheets/482943.pdf
http://uk.farnell.com/prowave/m165d25/atomiser-ultrasonic-liquid-1-65mhz/dp/1007369
http://www.farnell.com/datasheets/81205.pdf
Atomisation is important because a very small particle size means less bonds to break to release the stored energy.
RM :)
evolvingape
Hi Everyone,
http://www.gordonengland.co.uk/ps.htm
A schematic of the Plasma Spray Process which can be modified to provide the compression and expansion phases we require for use in a Plasma Injector to control and shape the fluid flow.
RM :)
evolvingape
Hi Everyone,
http://www.gordonengland.co.uk/ds.htm
A schematic of the Detonation Plasma Spray Process which is the principle that the Plasma Injector is based upon. The function is further improved by the De Laval shaped insert. The powder addition will no longer be required. The Nitrogen purge may work very well as part of the priming cycle. Fairly simple to adapt this known technology to Plasma Injector designs. Note the water cooled barrel which is already incorporated into PRotoMax designs via mounting within the water sump of the system and so both injector and rotor are permanently submerged.
RM :)
evolvingape
Hi Everyone,
Air may not itself be pure enough to provide the Nitrogen we need without some contamination that would foul the Injector and Rotor. It will be possible to incorporate a fractional distillation process to separate the air into its different gases using known technologies.
http://en.wikipedia.org/wiki/Air_separation
http://en.wikipedia.org/wiki/Liquid_air
RM :)
evolvingape
Hi Everyone,
Now let's talk about sea water distillation in the next few posts:
http://en.wikipedia.org/wiki/Multi-stage_flash_distillation
RM :)
Schematic of a multi-stage flash desalinator
A - Steam in
B - Seawater in
C - Potable water out
D - Waste out
E - Steam out
F - Heat exchange
G - Condensation collection
H - Brine heater
