PLASMICS
Started by evolvingape, August 21, 2011, 11:22:46 PM
evolvingape
The purpose of this thread I intend be twofold...
Community build a database of information for experimentation with plasmics...
Play with ideas on where plasmics could go... and make interesting lines of inquiry...
I have put up an interesting design and some information to analyse at your leisure...
Any experts knowing how to generate the required HV DC and RF frequencies economically for the home builder... a thread sharing your knowledge might be incredibly productive at this time...
Here is some basic info on RF...
http://www.vintage-radio.com/projects/signal-generator.html
One of these stimulating a RotoMax might create a very interesting reaction when a pulsed jet of high energy plasma enters the area of maximum fluid compression, inside the rotor,  and collides with the water jet ahead acting as the low energy mass flow buffer... the friction interaction, temperature balancing, and energy wave drag dynamics will be a fascinating study in themselves... a tip of an iceberg... and the energetics is any chef's soup ;)
Generate the primary trigger, balance the pressures within the priming cycle to provide timing and content by volume, manipulate the energy conversions of different fluids to desired energy potentials, detonate and shape the resultant fluid flow to produce thrust...
Good Times... Have Fun...  ;D
RM :)
evolvingape
Hi Everyone,
The PRotoMax System incorporates a Tesla Turbine Water Pump, powered by a DC Motor prime mover, to generate water mass flow through the PRotoMax.
The Everyman Wet Cell generates the primary trigger for compression via the HELP before injection into the PHELIS for Plasma variation and detonation functions. The HELP is powered by a DC Motor which also powers the Air Compressor for PHELIS Nitrogen injection. The HELP and Turbine Air Compressor are coupled via a magnetic slip clutch.
The PRotoMax is mounted within the water sump of the system.
PRotoMax fluid exhaust is vented into a reservoir chamber where it attains a pressure balance in the system via steam regulation, maintaining the system water level, and is regulated via turbine back pressure once the system is up to operating temperature.
The Steam Injection Variant allows the steam pressure to be utilised for either secondary injection into the PRotoMax or to power the Tesla Turbine Water Pump from Steam allowing you to remove the second DC Motor from the system.
Some information links:
http://www.magnomatics.com/
http://www.freshpatents.com/Variable-magnetic-coupling-of-rotating-machinery-dt20080626ptan20080149445.php
RM :)
evolvingape
To not be continued...
RM :)
evolvingape
Hi Everyone,
I have been trying to move on and work on other commitments but my mind will not let me until I finish this thread. It is the last in the series, requires completion, and so without further ado let's get on with it.
RM :)
