OVERBALANCING WHEEL WITH SLEWING RING
Started by weri812, August 29, 2011, 11:48:34 AM
weri812
@all
From Spang
                                    OVBERBALANCING WHEEL WITH 'SLEWING' RING
                                    ________________________________________
The 'Main-wheel', is caused to rotate by courtesy of a form of SLEWING-RING.  I say 'a form' of slewing ring, because this
slewing-ring is made up as follows:   The slewing-ring itself, is made of either, wood, metal, or plastic ----------------
it doesn't matter which.
This slewing-ring, has a solid center, which it is seperated from, by 'rollers' ----------- bearings, of some sort!
This center has an offset pivot to one side, (left) and a fairly large weight embeded in its right-hand side.
See drawing.  (It can also be 'pulled' down, by a 'tensioner' -------------- MY preference!)
The central wheel, is made to rotate, at the same speed as the 'rim' of the Main-wheel, by courtesy of, two (2) speed
exchange cogs ------------ one being attached to the 'rim' of the Main-wheel itself! (6 O'clock.)
If it were not for the weight that is embeded in the solid, & 'pivoted' center wheel ------- it could not work!
Imagine the 'slewing-wheel' WITHOUT any added weight!  The turning force it would make on the 'rim' of the Main-
wheel itself, would be TOTALY balanced by the force generated on the central-wheel!
Because the 'slewing' ring, is ALLWAYS heavier, on one side, than it is the other ---------------- it OVERBALANCES!
The 'pivoted' solid center ------- is supported externaly, as are the 'bridging' cogs.
The force generated on the 'rim' of the Main-wheel, is greater than the force generated on the central-wheel -------------
so that, when they meet, the greater force 'wins'.
Gentlemen, I think I've done it!(?)
Incidentaly, the further to the right-hand side, of the solid central-wheel, the weight is embeded ---------- the better!
PUT YOUR MIND IN GEAR BEFORE  YOU PUT YOUR MOUTH IN MOTION
fritznien
yes one of bill's, if you think it so good, redraw the thing so one can see what your talking about.
i can not make heads or tails out of it.
fritznien
SPANG
A clearer picture is on its way.
SPANG.                              (BILL.)
FatBird
Good points fritznien,
It is clear as MUD.  LOL
weri812
here is new picture  will not let me eddit old one
