Confirming the Delayed Lenz Effect
Started by Overunityguide, August 30, 2011, 04:59:41 PM
0 Members and 38 Guests are viewing this topic.
Farmhand
Quote from: synchro1 on April 18, 2013, 08:21:54 PM
  I believe this SBC tank reonance drives my high speed neo tube in series with a battery and reed switch, when the r.p.m. exceeds the reed switch limit.
This is entirely possible, simply put the pulses to the coil create harmonics and if the harmonics are of a low enough frequency and the Q is good enough the rotor could see the harmonics as driving "pulses" and the rotor speed would increase relative the influence of the harmonics. Still the energy in the harmonics is from the supply, it's oscillating energy.
Cheers
synchro1
Over 25k the resonant frequency begins to drive the neo tube, but it takes 1/2 a minute to run up to that speed, then "Shazzammm" it begins to "Hyper Accelerate" at around 10,000 r.p.m. per second up to near a 50k plateau. I tried disconnecting the battery, but it droped dead. I'm pretty sure the reed switch is stuck closed. There's an open circuit, but no longer any measureable amp draw.
Magluvin
Quote from: synchro1 on April 18, 2013, 10:39:08 PM
Well hot dang!!   ;)   Any vids?  ;D
That reed switch must be a champion.  ;D   I have a few of them. I like the ones that the reed pulls out of the relay when you straighten the leads. Some at RS are sealed, last I got some. I cut the plastic carefully around the end of the relay to remove the reed and POOF!  An amazing amount of super fine wire coil jumped out like a can of peanuts, um, I mean snakes. lol  It was one that was 1024 ohm.  At first the sound came and I thought I broke the reed, and then I didnt understand what I was seeing as there was sooo much wire and I just didnt get it for a couple seconds. I laughed. I got a pic of it and its posted here somewhere also. It literally 'unsprung' outward and expanded.
Reeds have an upper limit of their freq of operation. I dont know what the RS ones are. But maybe being in close proximity to that diametric mag, as they are strong, I have a few  in different sizes, the field is strong enough to take the reed contacts beyond that rating. They have resonant freq also, and show also at harmonics there of.
Mags
synchro1
It runs completly enclosed to protect from magnet fragmentation. I may cut a window through the side. I have to lasertach from below, half off a countertop.
The coil grew cold to the touch after warp factor!
The reed switches vary widely in their performance. Maybe one in five will reach these upward frequencies.
Magluvin
