Confirming the Delayed Lenz Effect
Started by Overunityguide, August 30, 2011, 04:59:41 PM
futuristic
Great work.  ;)
I think it would much safer if you would move the magnets to the inside of the plastic ring.
CRANKYpants
Quote from: futuristic on October 23, 2011, 12:57:02 PM
Great work.  ;)
MY THOUGHTS EXACTLY  ;) AND DRILL A HOLE IN YOUR DISK (THE SAME SIZE AS YOUR CORE) SO YOU CAN MOUNT YOUR COIL IN THE SAME PLACE AT THE EXTERIOR.
YOU ALSO HAVE ENOUGH SPACE (I THINK) TO DOUBLE YOUR FREQUENCY (AND INDUCED COIL VOLTAGE) BY DOUBLING THE NUMBER OF POLES (INSIDE YOUR DRUM).
IF YOU ARE REALLY CRAFTY AND ENERGETIC - YOU CAN EVEN MAKE A CORE SPOKE PATTERN AND PLACE IT INSIDE THE DRUM WITH CORES ON EACH SPOKE.
YOU WILL HAVE TO MATCH UP A NORTH POLE SPOKE WITH A SOUTH POLE SPOKE ON THE OTHER SIDE BUT YOUR FLUX TRANSFER THROUGH YOUR CORE WILL BE HIGHER SO YOUR INDUCED EMF WILL ALSO BE HIGHER... WHICH WILL IMPROVE OVERALL PERFORMANCE SIGNIFICANTLY . 8)
IF YOU ARE EVEN MORE CRAFTY YOU CAN START THE ROTOR WITH THE STATOR REMOVED AND GRADUALLY INSERT IT INTO THE ROTOR THUS MECHANICALLY VARYING THE LOADED GENERATOR SPEED.  :P
CHEERS
T
shimondoodkin
i am not sure if this correct,
but something i have noticed.
kapanadze device may have something shared with this device.
in both videos they call it cold electricity they tune the current to be cut off at top of sine wave. because they say because of phase shift of the current starts to flow only after voltage begins to be high enough.
so they don't let the voltage flow.
but the not flowing voltage can charge a capacitor.
as i grasped from http://jnaudin.free.fr/kapagen/index.htm (there is overmore explanation in mit lectures near bottom about this cold electricity)
in this device you also tune the frequency so the phase shift will be most effective.
so that's the idea of similarity i have noticed
http://www.youtube.com/watch?v=D9UKBEEKx4w
@23min-25min
and
kapanadze explanation 1(russian)
http://www.youtube.com/watch?v=Uj5KX7_JHXo
@20min-~22min
gotoluc
Hi everyone,
just a quick update of how one could use an off the self Transformer with a small Capacitance in Series to create a Delayed Lenz Effect or Phase Shift.
Link to video: http://www.youtube.com/watch?v=6RtZh5bStD8
The Troid used in the video demo has a 0.3 Ohm DC Resistance on each coil and they are 35mH each
The Series Capacitance is 24uf
Shunt Resistor is 1 Ohm and load is 10 Ohms
Power out is 10.8 Watts
Power in is Reactive 0 Watts
Luc
futuristic
Fantastic. ;)
Some wiki:
QuoteThe portion of power due to stored energy, which returns to the source in each cycle, is known as reactive power.
If the loads are purely reactive, then the voltage and current are 90 degrees out of phase. For half of each cycle, the product of voltage and current is positive, but on the other half of the cycle, the product is negative, indicating that on average, exactly as much energy flows toward the load as flows back. There is no net energy flow over one cycle. In this case, only reactive energy flowsâ€"there is no net transfer of energy to the load.
In your case there is obvious transfer of energy to the load so congratulations. ;)
But I think you should not stop here. Because if everyone would use reactive power then el. energy companies would start sending bills for reactive power.
If when using reactive power the energy flows toward the load and back, then there must be a way to make self or almost self sustaining circuit which will still deliver (create?) energy for load. Perhaps some sort of LC tank in resonance?
Keep up the good work. ;)
