Confirming the Delayed Lenz Effect
Started by Overunityguide, August 30, 2011, 04:59:41 PM
synchro1
Starting at 4:03 seconds into the video, The time reads 4:57, the run battery voltage reads 11:35 volts. The ball runs till  5:05 and the voltage reads 11:35 and holding! That's over 8 minutes! The rise and fall frequency is a rocking charge on a fixed baseline like I demonstrated manually in the project 4 video. The ebb and flow of a slinky or Yo Yo. That pulse must describe a perfect sign wave.  A closed loop breath cycle of charge and power. Self loop disconnected, the neo sphere runs the source battery down like a direct short. More Lenz delay confirmation.
http://www.youtube.com/watch?v=YTjqcX6sigQ
The see-sawing effect  is a consequence of the rule that power can't run against it self through the same wire at the same time, but it can reverse direction, which we hear it doing in the single Hertz range.  This is the serenade of unity harmonic, the result of Lenz free operation. This setup is OU in bemf from the primary coil. I track that charge on the green multimeter. You can see it rise while the source voltage remains steady. A scope shot of the audio would be interesting.
DeepCut
Batteries are a notoriously inaccurate way of estimating generator efficiency.
I'm sure we've all been to battery university :
http://batteryuniversity.com/
Batteries can rise and fall, slowly and quickly, individual cell conditions give rise to uncertainty ... it's all bad news but it's the kind of pitfall we need to look out for.
Having said that, what is the longest it has kept the battery charge steady at ?
According to the technical stuff that's available to us all on the web, we need to let the battery rest for 24 hours after charging to get an accurate estimate of it's charge.
Even then, the real specialists say you would have to measure the specific gravity of each cell with special hardware.
This is the sort of stuff i came up against when i had only made a simple Bedini motor.
I didn't want to hear it, but it's the truth.
We have to be stringent with ourselves, otherwise we have a questionable device.
So the only real test is how long it can keep the battery at a seemingly steady charge.
If it really is giving us something extra, it should be able to run forever, obviously not a test we can do !
If it can run for a month with no degradation, then you either have OU or a battery that is more efficient than any in existence.
You've been exploring this for a good while now (is it five years?), what's the longest run you've done ?
All the best,
DC.
synchro1
Rocking a capacitor bank like one Lasersabre uses to replace his car battery with ought to prove something?
PiCéd
DeepCut
Synchro, what do you do when you 'rock' a capacitor bank ?
I'm sure i'm subbed to laser on YT, gotta check.
All the best,
DC.
