gyulasun
Hi Luc,
My "problem"  with such transformers is that you have to give input power continuously and although it sounds good the transformer gives it back (albeit with some loss) in the other half sine wave as Thane wrote but the bottom line is that input power should be created first and if millions of people would start using many kilo or Megawatts of reactive power from the mains, the utility providers surely would find out how to handle the situation and continue charging for electricity accordingly. It is hard to believe they would cooperate with the consumers...
Nevertheless, it is always good to learn from hands on tests.
Gyula
PS  No I did not shoot the video.
wings
Quote from: gyulasun on October 18, 2011, 12:33:37 PM
Hi Luc,
Gyula
this can be a solution?
Use of electrical power multiplication for power smoothing in power distribution James F. Corum
http://www.google.com/patents?id=kqiYAAAAEBAJ&printsec=abstract#v=onepage&q&f=false
http://www.energeticforum.com/attachments/renewable-energy/8622d1311265352-resonance-properties-rotating-ring-circuits-ring-circuits.pdf
Tesla everywhere
http://books.google.ch/books?id=ZNqo1zaZRTYC&lpg=PA215&ots=ZJXOJknmUP&dq=%22Resonance%20Properties%20of%20Ring%20Circuits%22&hl=it&pg=PA202#v=onepage&q=%22Resonance%20Properties%20of%20Ring%20Circuits%22&f=false
Overunityguide
Quote from: CRANKYpants on October 05, 2011, 06:52:19 AM
DEAR OUG,
I HAVE ANOTHER JOB FOR YOU FOR WHEN YOU GET BACK FROM YOUR BUSINESS TRIP THIS SATURDAY.  :-*
MAKE A BI-FILAR SERIES CONNECTED SECONDARY COIL FOR YOUR ORIGINAL LENZ DELAY TRANSFORMER SO YOU CAN SHOW HOW THE BI-FILAR WOUND COIL DIFFERS FROM THE HIGH IMPEDANCE SINGLE WIRE WOUND COIL.
CHEERS
T
Dear Thane,
This is exactly what I have done last week, and I have played several days with it by now. My bifilar series connected coil has two windings both of about 3 Ohms each. And I have used this coil as a secondary transformer coil just like in my first transformer video about the Delayed Lenz Effect inside a transformer.
For now my conclusions are: That when I run the setup on 950 Hz that for the bifilar series connected secondary transformer coil I am getting the same effect with my LED light bulb load, just as in my high impedance secondary coil transformer experiment. 0.2 Watts input power drop going to the primary coil.
But for now, because my bifilar series connected secondary coil has got two windings of low DC resistance, I had decided to load them with a 5 Watts 12V incandescent car light bulb. (also on 950Hz) So after doing this I came to the conclusion that my input voltage going to the primary had to be higher, so this is what I did. And after increasing the input voltage going to the primary coil I saw the following effect taking place:
After connecting the load to the bifilar series connected secondary coil, the input power going to my primary coil went up by 4 Watts, and there was going about 3.2 Watts to the 12v car light bulb in this scenario. So 80% efficient by now, was the best I could squeeze out of it.
Quote from: CRANKYpants on September 29, 2011, 04:38:43 PM
HEY LUC,
YOU HAVE A RESONANT CIRCUIT THERE...  ;)
I STILL WONDER IF THIS (AND OVERUNITYGUIDE'S) TRANSFORMER DELAYED LENZ IS ACTUALLY A CORE HYSTERISIS DELAYED EFFECT OR A BIT OF BOTH?
CHEERS
T
To continue with the above, I now am thinking also that the Lenz Delay has to do something with the "CORE HYSTERISIS DELAYED EFFECT" which you are describing above, rather then that it has to do something with input or output coils of the transformer... So for now I do think that building a proper core which can be saturated above a certain level can be the key to further enhance the Delayed Lenz Effect.
Thane I think that you are aware of the Gabriel Device? Which can be viewed in the following thread:
Gabriel Device, possible COP=8: (Operation: Thane Heins effect based device)
http://www.overunity.com/index.php?topic=10518.0
Furthermore, I do think that the following Tesla patent can be very helpful when trying to do further experimentation in this Delayed Lenz Effect field:
http://www.teslauniverse.com/nikola-tesla-patents-433,702-electrical-transformer
Ok, I think that was all for today,
Wishing you all the Best and With Kind Regards, Overunityguide
Kator01
DeepCut
Just a small update.
Yesterday i tested a bifilar-wound, serially connected coil, the same 0.25mm coil i previously had as straight-wound, the performance increases in terms of a rise in frequency and a drop in current draw are on the order of four times better than a straight-wound coil.
Here's a short clip of the new coil in action. I plan to get a cheap HD camera soon, apologies for fuzziness and mesy desk ;+}
http://www.youtube.com/watch?v=t8DEYX-e6_Q
Best to all,
DC.
