gotoluc
Here is the identical setup but connected to the Grid
15uf series capacitor, 1 Ohm Shunt, 10 Ohm Load @ 6.70vac
If this was Saturation then where are those Peaks?
Luc
gotoluc
Quote from: nul-points on October 28, 2011, 08:08:30 PM
yeah, this is what i remembered seeing - a YT video by user 'selfonlypath' showing results obtained with his 'Transverter' setup (2x MWO trafos modified & connected together, then driven with an 'H' bridge)
  http://www.youtube.com/user/selfonlypath    eg., see 'Transverter 1'
at a combination of resonance and with the i/p volts just passing thro' a threshold, the o/p sine wave 'snaps' into a more triangular waveform with elongated peaks
the snapshot below captures the moment when the o/p changes from a sine to a 'triangular' wave with peaks
cheers
np
Thanks nul-points for posting this video once again. It was posted on page 14 by plengo: http://www.overunity.com/index.php?topic=11350.msg301689#msg301689
This great researcher explains and demonstrates that one needs an accurate timing circuit to recover energy from a Reactive circuit.
I have said and I believe we are subject to the same.
Anyone interested should study this technique and post their ideas of a recovery/recirculating circuit.
Thanks for sharing
Luc
CRANKYpants
Quote from: gotoluc on October 28, 2011, 12:34:19 PM
THIS POST WAS EDITED
under load it's at 1,130ma
Luc
IS THIS 1.13 mA OR IS IT 1.13 A?
IT WOULD BE NICE IF WAS 1.13 mA BECAUSE YOU EFFICIENCY WOULD BE 32297.3%  8).
OTHERWISE INPUT CURRENT = 720 mA AND PRIMARY DC RESISTANCE = 0.3 OHMS
IF PRIMARY POWER FACTOR IS INDEED 0.0 THEN Pp = 0.216 WATTS WITH AN EFFICIENCY OF ONLY 2078.2%.  :-[
IF THE PHASE SHIFT IS 81 DEGREES (AS I SEE IT) PF = 0.15 AND IF Pcurrent = 727 mA AND Pvoltage = 112 V THEN
Pin = 112 x 0.727 x 0.15
= 12.7 WATTS AND Pout = 4.49 WATTS AND EFFICIENCY = 35.4%  :'(
A PHASE SHIFT OF 87 DEGREES OR PF = 0.052 GIVES AN EFFICIENCY OF 105%.
IF THE DC INPUT CURRENT IS 1.13 A AND THE DC VOLTAGE IS 12.3 VOLTS THEN THE EFFICIENCY IS 32.3%
PLEASE EXPAND YOUR TIME AXIS SO:
1) WE ONLY SEE 1/2 OF THE SINE WAVE (180 DEGREES) AND THEN
2) EXPAND THE VOLT/DIV SO THE LINES ARE STRAIGHT UP AND DOWN AND THEN
3) MAKE THE YELLOW LINES EQUAL ON BOTH SIDES.
NOW WE CAN CALCULATE THE PHASE ANGLE CORRECTLY.
ALSO NOTE POSITION OF RED "POWER" SINE WAVE IS SLIGHTLY HIGHER ON TOP AND NOT QUITE EQUAL FOR A PF OF 0.0 - CAN YOU TWEAK IT WITH ANOTHER CAP VALUE?
CHEERS
T
gotoluc
Hi Thane
it is 1.13 Amps and your math seems to be correct.
I always learn new stuff as I go so there is nothing wasted (other than power ;D)... I'm only going to get better at this.
Thanks for everyone's input
Luc
PS hey! nice scope shot. That is the ultimate one. We'll get there
gotoluc
Hey Thane,
have a look at these Shots
I decided to re-test my GTL-90 compared to the Toroid and the GTL-90 is better
First shot is GTL 90 with 22 ohm shunt, 1uf series cap, 10 ohm load @ 0.42vac
Second shot is Toroid with 22 ohm shunt, 1uf series cap, 10 ohm load @ 0.42vac
Let me know what you think
Luc
