DeepCut
I've been testing the new setup, with occasional pauses for sleep and food ;+}
It seems that it generates more power than it uses but i will have to wait until i get a scope (new year).
Here's a vid :
http://www.youtube.com/watch?v=vBDOOSOhbz0
Thanks for reading,
DC.
gotoluc
Quote from: DeepCut on December 08, 2011, 08:50:09 AM
Here's a vid :
Thanks for reading,
DC.
Excellent looking setup DC!
Does the coil Voltage output stay at 446vdc when you connect the Amp meter?
Thanks for sharing
Luc
DeepCut
Thanks Luc :)
The voltage RISES due to the amp meter being a small load and the acceleration-under-load effect taking place !
*** EDIT ADD ***
it shows that in the video but my voice is a bit mufled
*** EDIT ADD ***
On Thane's advice i will try them connected in parallel, but i tried that with the old setup and got no AUL but we'll see.
As it is the effect only supports a very small range of loads.
I'm having trouble measuring voltage and current at the same time, sometimes it works and sometimes it doesn't, on one occasion i got a shock from one wire only which surprised me.
I'm testing smaller coils as well, 50 grammes rather than 500 grammes of copper. The effect is much better with the 50g coils for some reason.
Cheers,
DC.
wojwrobel
hello
have you guys tried to put inductor in series with load ? it also changes the cos(phi) by 90 degrease!
something similar to stanley meyer circiut but just one inductor??
oh maybe stans work was based on phase change so the primary side of transformer didnt see the load? so he could make hydrogen by regular electrolysis but transformer didnt see the amp draw? he used few khz so xl=2(pi)f*L the bigger the (f) frequency the bigger the phase shift!!
well we cant get very high L without high wire resistance because L=uN^2A/l so many turn are needed (or high (u) core ) the resistance is problematic, only one figure which is frequency is left to play !
so we can get cos (phi) with the formula
(http://img861.imageshack.us/img861/946/cosphi.jpg)
so if we do hi L hi R  or low L low R it really doesnt mater whats mater is the frequency!!
you can put figures to formula for diferent coils and you see that only figure you can play is FREQUENCY!!!
you can find some more calculation here
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/rlimp.html#c1
cheers from poland
wojsciech
