hoptoad
Quote from: synchro1 on April 02, 2013, 04:17:35 PM
Look at this, and read the fine print. The coil looses it's resistance to change in current direction, as a consequence of the spontaneous high voltage charge that builds between the cross current windings.
Indeed, read the fine print very carefully, regarding which energy he is referring to.
"In that the stored energy is a function of ....." Quote Nicola Tesla
Cheers
crazycut06
Quote from: skycollection on April 02, 2013, 12:53:36 PM
I say ZERO LENZ SKYDYNAMOTOR, because the friction bitwin the magnet rotor and the pancake coil is 0...and you will see that in my next video, and because the pancake coil is a zero...!
saludos, jorge
Hi skycollection,
In your test, let the rotor pickup its maximum rpm speed, check it before engaging the load, then after the load is engaged check the rpm again, small rpm drop is a little bit tricky if you don't check with an rpm meter.
Cc
synchro1
Here's an inspired design for size and positionig of "Spiral output coils" off a "Spiral spinner".  Supernova remnant pulsar:
"The radio emission we observe comes from electrons "spiralling" along the magnetic field lines".  The counter spin is visable!
kEhYo77
And here is an experiment of J.L. Naudin confirming phase shift in a laminated transformer core.
http://youtu.be/NQ5xnyj7xe4
You can see him probing the induced magnetic field around the core with a Hall sensor. The shift happens at some distance from the oscillating coil.[/size]
This confirms the method used by Tesla to achieve a second phase in one of his 4-pole AC motor, having only one AC input signal.
It is achieved by moving 2 stator coils further back on their cores, away from the rotor.
So, to build a delayed Lenz generator coil we need only a long core protruding from the front of the coil.
... just as Anguswangus did with his PMH gen coils.
synchro1
KEY077,
Anguswangus did more then extrend his coil cores, he generated an induced horseshoe background magnetic field with a counterwound sister coil in close adjacency. I believe this magnetic field interferance allows him to shorten his core length.
