Using this "Sea of Natural Energy"
Started by Hope, September 11, 2011, 03:54:13 AM
Hope
 I got a clear picture of what is going on with this natural sea of energy now.   Everything has a natural cohesion to like atoms (similar to water surface tension) But all wavelengths have it.  So when we disrupt it, it re-balances using it's own energy.  If we disrupt the electrical properties say using voltage spike (the higher the voltage the more energy types it disrupts, the more the potential differences the more the disruption).  Like the bigger the rock we throw in the pond the bigger the splash and not only in the water but splashes on the shores too.  So all we have to do to use this natural re-balancing energy which is coming thru the air (bad conductor) is provide it with a good conductor that doesn't become saturated (we have an antenna that is attached to a load which provides a path that is less resistant than the air) if it does become saturated there is no potential difference and the flow stops using it, and uses the air again or another less resistant path.  So HV disrupts the cohesion, this imbalance is a potential difference.  Nature flows to balance the potential difference, we make a path and work (a load)to keep this path less resistant than the air.  BINGO we get to use natural energy (of course we may have to keep the spark gap going to keep disruptions causing a potential difference).  Perhaps just the loads draw can keep it flowing??  Now this is how it is done and I believe we can all make devices using this principle.
Open sourced,
Richard T. Williams
edited
