TonyWoodside 8XA Raise 1 litre water 15C To 90C in one Seccond ?
Started by ramset, September 12, 2011, 01:31:50 PM
ramset
TONYWOODSIDE 8XA Circuit
Now I see its for sale on Ebay
http://www.ebay.com/itm/Stanley-Meyer-8XA-Circuit-HHO-Generator-/160607306490
Under the Mans own name and 100% pos feedback??
Wild Temp Claims  [below],I believe they are using this 8XA circuit?
http://www.youtube.com/watch?v=fsmdSkYEp6M
Text,
Uploaded by THEWATERENERGY1 on Jul 18, 2011
HEAT / STEAM RESONATOR (ELEMENT) STAN MEYER STYL ....CIRCUIT TEST
90VDC / 1000MA ...AT 1.2 KHz
WE ARE TESTING THIS ELEMENT FOR THE HOME HEATING BOILER.....HEATUP 1LITER WATER FORM 15C TO 90C CELSIUS IN JUST 1 SEC ....THAT IS FASTER THAN A MAGNETRON......ELEMENT IN THIS TEST IS 3XXX 3#INCH....WE US A NEW CIRCUIT FOR THIS TEST
WHAT WE DOING IS TESTING A CIRCUIT AT SEVERALS FREQENCY AND VOLTAGE,,
IN ORDER TO FIND OUT WHAT THE EXACT COMBINATION IS TO FIND RESONANCE IN THE WATER AND HEAT IT VERY QUIKLY,AT THE RIGHT RESONANCE IN THE CIRCUIT,AT THE LOWEST AMP / CANCEL OUT THE AMP.....
THE REASONS WHY WE NEED A HEAT RESONATOR IS, TO DEFROST THE
YOUR WATERFEULTANK IN THE WINTER, INCASE THE WATERFEULTANK IS FROZEN.
AND WE WILL US THE HEATRESONATOR IN A HOMEHEATING BOILER TO HEAT UP THE WATER AND PUMP THE WATER A ROND YOUR HOUSE SO
WE HAVE A WARM HOUSE IN THE WINTER FOR LAST ENERGY AND EMISSIONS....IN EUROPE WE US A LOT PROPANE AT THIS TIME....TO WARMUP YOUR HOUSES
IN THE FUTURE WE WILL POST MORE INFORMATION AND THE SYSTEM AT WORK.
These fellows Emailed me back and said they will be sharing the Details Shortly??
Anybody have more info on the 8XA reverse engineered Meyers Tech??
I have seen it other places recently?
Thank you
Chet
Thanks Grandma
TheOne
This is interresting!
I will check on ebay and youtube tonight to see, maybe it is easy to convert an old water heater with this circuit and save a lot of money
DreamThinkBuild
Hi Chet,
Thanks for the links. In the video he says the middle stainless steel plate vibrates the most. Now I'm wondering if this is more mechanical heating than electrical?
Imagine each thin stainless steel plate as a capacitor plate with one end that is firmly fixed. This makes the extended end portion act like a cantilever beam. If the inner plate is negative and one of the outer plates goes positive the inner plate on the open end will bend toward the outer charged plate.
Now if you alternate the outer plates with a square wave 90 degrees out of phase with each other, the inner plate should vibrate back and forth at the frequency 1.2khz he uses. The mechanical stress on the plate should induce heating. Just like bending a piece of solid wire back and forth until it heats up and breaks.
That is just my thoughts on how it could work, would like to see a design schematic also.
ramset
Hi fellahs
This Vid was presented by MonsieurM on the  new Peter Davies thread At energetic.
I felt it needs to be Vetted?[W=]
Exnihiloest did the math on this claim.
it would take 313kv to do the same thing !
If these guys are getting anywhere near this it would be a monster.
Chet
Thanks Grandma
CompuTutor
Is the heat rise real of measured,
anybody stuck a finger in it after  ?
I ask because if they are using an infrared thermometer,
they may only be measuring an IR sonoluminescence effect.
