The electric field of a magnet
Started by Dave45, September 14, 2011, 06:59:44 PM
Dave45
Thanks Dreamthinkbuild
Leedskalnin said the north field was stronger than the south and here's why if the galaxy is moving in a right hand spiral the electrons that couple with the magnetic field on the side that is moving in the direction with the A vector will be stronger than the electrons moving against the direction of the A vector.
Hard for my simple mind to convey but if you refer to the model we made on the piece of paper you will see what I mean.
Dave
DreamThinkBuild
Hi Dave,
QuoteLeedskalnin said the north field was stronger than the south and here's why if the galaxy is moving in a right hand spiral the electrons that couple with the magnetic field on the side that is moving in the direction with the A vector will be stronger than the electrons moving against the direction of the A vector.
Are there any examples of this effect in HV plasmas?
I think the effect might be usable for a magnet if we wobble the field in and out of a coil, I haven't tested this yet but if you take a ring magnet(bigger the better) with N up, S down and place it on a motor shaft but at a slight angle 5 to 15 degrees. Then place a coil above it and run the motor it should produce an output. It will probably be low power but I wonder how Lenz will be effected by it since we are not moving the magnet in a linear sense only using the wobble of the field. I attached a drawing.
MonsieurM
Important note: in nature nothing is done at random; so should you when you build your coils , the choice of gauge and turns is related to your entire set up by the golden ratio...this is the key to OU
:cheers:
here is an example for you :  :notworthy:
13-Year-Old Makes Solar Power Breakthrough by Harnessing the Fibonacci Sequence | Inhabitat - Green Design Will Save the World
QuoteWhile most 13-year-olds spend their free time playing video games or cruising Facebook, one 7th grader was trekking through the woods uncovering a mystery of science. After studying how trees branch in a very specific way, Aidan Dwyer created a solar cell tree that produces 20-50% more power than a uniform array of photovoltaic panels. His impressive results show that using a specific formula for distributing solar cells can drastically improve energy generation. The study earned Aidan a provisional U.S patent - it's a rare find in the field of technology and a fantastic example of how biomimicry can drastically improve design
you need 2 elements (2 wires )to create the third one like in the rodin coil....:thinking:
http://www.alexpetty.com/wp-content/uploads/2009/09/rodin-coil-all-3-windings-282x300.png
  http://i1206.photobucket.com/albums/bb444/MonsieurM/369-1.gif
remember how you build a rodin coil and the 369 picture will make total sense ;)
:D
Kator01
Hello,
the Structure of the magnetic fields of permanant magnets was discovered way back in the 1970 by Howard Johnson:
Please go to page 6 in this book here :
http://www.scribd.com/doc/34317/Spintronics-The-Secret-World-of-Magnets-2006-by-Howard-Johnson
They mapped the fields systemtically : starting with page 37
Kator01
Dave45
The A vector field and how it couples to the magnetic field
The magnetic field is a neutral field until its coupled by the A vector field which gives it a spin direction
