FIRST FREE ENERGY DEVICE REACHES MARKET IN OCTOBER -- The Game Changer is Here
Started by chessnyt, September 16, 2011, 06:57:24 PM
The new poll  starting 2-4-2012:  LENR technology
a) will soon lead to the end of the fossil fuel era and become the new standard.
b) will compete with fossil fuels for decades to come eventually replacing them.
c) will not only phase out fossil fuels but will also lead to the trials of the current corrupt powers in charge.
d) will lead to all of the above.
chessnyt
Quote from: Rosemary Ainslie on May 19, 2012, 10:52:13 PM
Guys, it's one thing to let MileHigh dominate this thread - but it would be catastrophic if he were to bring it to 'lock down' which is what he's trying to do.  I really think it may be as well to ignore him.  Just a thought.  What's nice though is to see the commitment to LENR from the rest of you.  That's always the spin off from these 'contentions'.  But it's my opinion that Harti would close up this topic in a heartbeat if and when he could get an excuse.  And MileHigh's giving him that - by the wagon load.
And bear in mind.  They're getting REALLY frantic.  First barrier to fall is courtesy LENR.  Who knows what's next.  And as it's said 'if winter's here - can spring be far behind?'
Kindest regards
Rosemary
added
Very wise advice, Rosemary.  I'm all done setting the record straight at least.
Best Regards,
Chess
Chess:
It's unbelievable how people will compromise themselves sometimes.
QuoteYou actually made two consecutive mistakes.
First, you assumed I didn't know what a pressure relief valve was (which was false):
You call that a "mistake?"  The fact that I made an assumption based on what you posted is a "mistake?"  You should be embarrassed by stooping so low.
QuoteAnd then you showed your ignorance by not being aware that a boiler can fail even when a pressure relief valve is in place and working properly:
Really?  Did you you ask me if 100% of all boilers manufactured are guaranteed not to fail before the pressure release valve kicks in?  The fact is that you did not ask me that question.  Are 100% of condoms manufactured guaranteed to work properly?  You are just making a loaded accusation at me.  It's bullshit, you are stooping low again.
So your whole premise that "I made two mistakes and you taught me" is total bullshit.
Then I asked you about your plans to do an E-Cat based battery charging system just to make you squirm again.  You still haven't had the character or courage to acknowledge my comments stating that it likely won't even work.  Reading between the lines my conclusion is that you never even considered the efficiency losses for each step - which puts you in newbie territory.  You will likely be better off just connecting straight to the grid.
Can you even post a link to an industrial-grade 10 kilowatt turbine?  It's going to have to run closed loop with a condenser and last at least 30 years.  You will need an industrial-grade transmission to bring the turbine speed down to mains frequency.  That sounds like something really damn expensive to me.  The ROI might be 75 years for all I know.
The feeling that I am getting from you is that your "project" is just a pie-in-the-sky fantasy for now and I would not be surprised if it would cost a fortune.  Plus the high-temperature-steam producing E-Cat is pure vapourware as we speak.
QuoteTrying to change the subject just makes you look even sillier (if that's even possible) and increasingly pathetic.
Take a look in the mirror.
Rosemary:
Don't give me your paranoid rantings crap.
chessnyt
Quote from: Magluvin on May 19, 2012, 11:02:08 PM
MH said,
Can you tell us some more about the E-Cat-based battery charging and inverter system that you want to build?
Yep, distraction.
Mags
Yes, it is quite obvious, isn't it?  It's even more pathetic than it is obvious.  Especially now that he has sealed his fate and denied ANY wrong doing.  But Reply #1194 says it all IN HIS OWN WORDS DIRECTLY QUOTED FROM THE SOURCE  ;D   It's not hard for people to see the obvious truth.
Best Regards,
Chess
Chess:
Try to keep a stiff upper lip and try to ignore the elephant in the room.
Good luck.
chessnyt
The following quote is from Rossi today:
"Andrea Rossi
May 19th, 2012 at 5:10 PM
Dear Franco:
We are working with good stability at 600 Celsius degrees. This, if confirmed by the next tests, clearly opens all the possible doors.
Warm Regards,
A.R.
p.s. Today, Saturday May 19th,right now, 6.10 p.m. in Miami, I am working at 600 Celsius with the new E-Cat"
It's exciting to watch history in the making  ;D ;D ;D
Get excited people,
Chess
