Time Travel Research
Started by telemachus, October 10, 2011, 03:51:51 AM
onthecuttingedge2005
Sorry guys.
It was written as VB script.
If Ohm = "" Then Ohm = 0
simply says, If Ohm has no string then it is equal to an integer of 0.
Wilby, if you wish to test it you can make a .vbs file and test it, it will receive no error.
CuriousChris
Well I don't know what meds willy is on, but its pretty strong stuff, perhaps he should cut back.
Your 'code' is perfectly fine cutting.
In psuedocode which in this case is longer than the code.
If Ohm is an empty string then
   set Ohm equal to zero
CC
