Ibpointless2 Crystal Cells
0 Members and 28 Guests are viewing this topic.
jbignes5
 I wonder if the oil immersion process can grow the crystals on the metals without bulk water being involved? Oxidized metal might not work for like magnesium and we might get the crystals to grow on the magnesium without using water and bypassing that process of oxidation making a direct deposit to the metals.
Oil is used to give it a resistance to break down like electrolysis as well or shorting.
triffid
this is how i am calculating my watts:
volts x amps= watts
millivolts x milliamps=milliwatts
When i get 8.02 volts and .20 milliamps I do it like this 8.02volts x1000millivolts/volts x .20 milliamps=1605milliwattsx1watt/1000milliwatts=1.6watts
you have to convert volts to millivolts so you multiply by 1000.Then divide by 1000 to get watts out of milliwatts.This is how I have been doing all of my calculations.
So 1.6watts is what I am getting out of my aspirin (6)cells now.
And for the six cells of vitamin C cells,7.8 volts and .45ma   3.51watts
So both panels have dropped in their power quite a bit the second week of life.
triffid
.3amps =300 milliamp
.3ma=.3ma
I know the difference.I was hoping IB2s new cell was 300ma. 300uamp tells me its alot smaller.
triffid
Thanks for the voltmeter tip IB2.I think I will be getting me one.
1amp=1000 milliamp=1000000uamp(microamps).
PhiChaser
Quote from: jbignes5 on February 21, 2012, 08:16:49 PM
Now listen carefully IB. What you need to do is oxidize the electrodes and let them dry thoroughly. Now this is the easy part. Put them in layered fashion Copper/Magnesium/Copper/Magnesium and hook them in parallel. Put cheese cloth in between each layer that has been pre-soaked in alum crystals and boil it all in oil to remove all the air, water and oxygen. There you have it. Only the crystals will touch and everything else will be sealed from air and water! As it cools the crystals will solidify and create the connection in between the plates with only the water that is in the crystals<-pure crystalline water.
I havent done this yet because I need to get some magnesium and copper plates. I am gonna try it because I think this is the key... Oxygen is the problem here not water. Thats why Tesla used boiled oil coils to exclude oxygen from the coils and greatly extended the operating tolerances. This process could be used here as well...
I agree that water isn't the problem, it is oxygen. Man... I still need to get some alum.
@ triffid: 1.8v is awesome!!
PC
triffid
I do not feel so bad now.I was worried I had too much water in those vitamin C cells.They are still lighting an led tonight.I cant wait to try petro jelly on a new cell.triffid
maybe tomorrow?
