Ibpointless2 Crystal Cells
triffid
Well I have some interesting results to post.My little cells with pennies and aluminum foil and paper circles dried out over night.And fell apart when I started handling them today.Wet they gave me.5 volts per cell,today dried out they gave me only .004 volts.Once I applied pressure
the voltages started going up.I got a max of .057 volts.From totally (dry to me) paper that had been saturated with a epsom salts/morton salt sub solution the day before and the cells allowed to dry overnight with the electrodes in place.I could place the electrodes back on the dry paper and get voltages.Of course .057 volts per cell is not my aim.But if you are aiming for totally dry cells you could cover wet sheets of paper with sheets of aluminum foil and copper sheets so your crystal structure forms in response to the electronegative values of the electrodes.Then later cut squares or circles to make multiple cells for your panels.No more water needed.I guess I figured out a way to make thin sheets of these crystals?triffid
I still intend to make a paste and to see what happens there.
triffid
Actually IB2 ,you figured out how to make thin sheets of these crystals first with your big blue cell.With you wetting the notebook paper with a solution of epsom salts and morton salt sub.Once dried with your electrodes in place.I think we could dry large sheets of these thin crystals cut the dried paper to fit more electrodes of the same two metals.Use one set of metal sheets copper and aluminum.Set the wet paper between them,let the paper dry.So the crystal structure is set up for those two metals.Make thousands of thin sheets of crystals for those two  metals.triffid
triffid
Question,If the crystal structure is set up say for magnesium and graphite(a combination that usually gives the highest voltages),Could I come along with two copper electrodes and get the same high voltages?triffid
triffid
PB,when I think about the vacuum I think about the spaces between atoms ,not a lack of air really.The chair you sit on is full of vacuum.The table you sit at is not really solid but full of empty space.(vacuum).That is the vacuum we are talking about.Not a lack of air.The space between atoms.triffid
triffid
I know my results are more piezoelectric than ever before but no more water no more electrodes being eaten up.these cells could be packaged under pressure.Shrinkwrap comes to mind.triffid
