Rosemary Ainslie
And guys,
While this is on my mind - let me explain something about TK's video.  You'll notice that he applied a mere 3 volts or thereby to the circuit while applying 10 volts or thereby from the signal generator.  The components were thereby intended to be 'stacked' that the applied signal would overpower the supply.  This certainly accounted for the entire lack of evidence of an oscillation in the first video.  But it leaves MANY unanswered questions in the second.  My personal opinion is that there's some 'connectivity' in the circuit that's either intentionally or otherwise - not being disclosed.  I cannot - otherwise - reconcile the fact that he gets any oscillation over the circuit components.  Unless he's deliberately routing the signal onto the only inductance available on that entirely undefined inductive load of his.  That would develop a potential difference - at least.  In which case it may explain why the signal waveform reduces.  But there would need to be some path available.  And I can't see this from his circuit.  It's simply not clear how that wiring is done.  That inductor is also on the breadboard that holds the Q-array.
The other thing that he's trying to 'brush under the carpet' is the fact that his oscillation is never more than NOISE.  He seems to think that this is either robust or continuous.  It's neither.  Certainly NOT as is evident when he CLAIMS that the battery is disconnected. The one thing that was spot on - is that the applied signal over the battery is indeed sensitive to the 'off set'.  And albeit weak - that waveform across the battery was consistent.  But the 'off set' is simply a means by which the signal is applied in conjunction with a potentiometer that can - thereby - add to the resistance.  It's not 'negative' or 'positive' so much as 'higher' or 'lower'.  But INDEED.  That waveform is consistent with what we find.  But it most certainly is NOT possible without an applied signal.  And that signal does NOT need to come from a function generator as he's ALLEGING.
Anyway.  That's food for thought.  Hopefully TK will make things clearer as time goes by.  I was rather hoping for more force in all that argument of his - and more rigour in that rather sad little summation he offered. I'm rather inclined to think he was trying to trivialise everything.  I think we need some more transparency in his approach - if he's really going to manage a DEBUNK.
Kindest regards,
Rosemary
added
Rosemary Ainslie
@Glen Lettenmaier
I would caution you to acknowledge your sources - IF you're going to post over copious copies of information about batteries.  Else you're exposing Harti to unnecessary risk of litigation.
It's one thing to STEAL my paper.  It's an ENTIRELY different thing when you 'carte blanche' steal ownership of anyone else's.  Surely you've got SOME measure of professionalism there?  We'd all be glad to see some evidence of it.
Rosemary
spelling
fuzzytomcat
Quote from: Rosemary Ainslie on March 13, 2012, 03:15:38 AM
@Glen Lettenmaier
It's one thing to STEAL my paper.  It's an ENTIRELY different thing when you 'carte blance' steal ownership of anyone else's.  Surely you've got SOME measure of professionalism there?  We'd all be glad to see some evidence of it.
Rosemary
Reading members and guests,
For the record a re-post that I am now a "THIEF" as shown by Rosemary Ainslie ...... again without any proof of e-mails or forum postings references of the stated allegation only slander !!!!
fuzzytomcat
energy1234hope
Go away troll IT was interesting readiing before you stuck your nose in.
