which is better a magnet passing over the top of a coil or passing it over the
Started by cityvillian, November 17, 2011, 06:11:45 PM
cityvillian
I have a few questions would appreciate some help, thanks.
1) Which is better a magnet passing over the top of a coil (where the center hole is) or passing it over the side of the coil where more copper is exposed? Shouldn't the magnetic field pass a coil perpendicular to the copper wire? Yet in so many designs I see the magnets going over the top (where the center hole is).
2)  Also wouldn't  it be better to alternate the magnetic poles by  passing over the coil with a positive pole then a negative pole then a positive pole etc (to release more EMF and capture more EMF and magnetism by the cap and the other coils or secondary coil) , then to say always have a the same pole pass over a coil?
3) Im thinking of the circut for this, something like, Induction coil, resistor, cap, dioide, rectifier then power out .
Is this order correct or do I need a resistor after the cap and not before?
4)  My main confusion is, how do I get the cap to release it's charge when its full? Is this done with a higher rated diode that matches the cap?
Thanks in advance for any light you can eluminate my darkened mind with.
Rob
wojwrobel
ad1
You are making mistake ! you have to treat coil as two wire where the magnet passes thru the center (hole)
the best results would be if one wire have N and other S pole at the same time then nothing and then oposite!
so you have to desing you coil to have hole size as magnet size and each pasing wire thick as magnet, if you dont get it i can draw it for you;-)
ad2-4
if i would be you i would look on THANE HEINS work on youtube
hes idea is that the higher the frequency, the current in wire gets delayed vs magnet that caused this current to flow in wire so the lenz force is minimal
so check it out its worth looking and i dont thing that any other magic will work this guy is really have some good work there check it
cheers from poland
wojsciech
ps there is a site http://hyperphysics.phy-astr.gsu.edu/hbase/electric/rlimp.html#c1
where you can calculate this delay but in degrease 0-90 when 90 you have the best delay but you cant never get to 90 you can get to 89.9999999..... max its a tanegs function that never reach 90
so you have to know your frequency (hz) ,inductance (H) ,your coil resistance (ohm)
dig it so more you will find that you need high frequency(hz) so many magnets passing in 1 seconds
Quietman
Ok I Finally found true free energy, i do not use forums but this info needs to be out there, the problem i can see is, the costs are out of most peoples reach,  it is very simple way to get past what most are calling the gate in magnet motors, ok you will have to use your imagination a little while i explain, have you ever seen the small plastic toy cars where the wheels would pull off, well now imagine the wheels you just pulled off are magnets, (there are two magnets ) circular like 2 wheels on a rod. well anyway you can roll past the gate , i need funds to build mine, but i wanted others to know, i can guess it will cost A couple hundred just to constantly run one small L.E.D forever          Now picture flat magnets stuck together laying flat on a table you can drop the magnets the ones described above at the start and i seen the magnets roll past the gate!  it is truly amazing i can explain more and answer questions on this, i am 100% sure it works, this is not fake i am giving the info free so i have no reason to lie or get you to spend money on something that might work, this WILL WORK. i will check back on this forum but the forum is confusing i do not see where i am suppose to post this so maybe someone else can.
