SMOT
Started by KSW, April 11, 2005, 08:45:18 AM
peter_schmalenbach
Hello djancak,
we are looking for companies which have a laser cutter for the hollows (depressions).
Then the ball will pass the last 3 mm.
All stages must have accurately the same characteristics (features).
The sticky point is the connection of the end and the begin of the circle. This is at the moment between (among) the stages 14 and 15. If I adjust the stages 14 and 15 in the same way as the other good stages, then change the stages 11, 12, 13 and 16, 1 and 2 their (its) characteristics. The whole is a coherent (linked) magnetic field.
Werner Heisenberg (Nobel prize winner), Germany, said 1950:
A motor, only built up with magnets is possible, but we scientifically idiots cannot construct it. That only can make an outsider!
Best regards
Peter Schmalenbach
More details (Pictures, drawings, but text in German):
http://www.schmalenbach.de/patent
http://www.schmalenbach.de/video3.mpg      (Ball gets more speed during the run in the circle)
Best view: Wind. Media Player
If anybody thinks that a perpetuum mobile is impossible, then he should not pester an inventor who is just now building one.
Omnibus
@peter_schmalenbach,
Could you please cite the source of Heisenberg?s quotation in your post?
As for the laser cutter, I?m afraid the problem may be more complex than merely the adjustment of stages 14 and 15 as the other good stages through cutting the track with a laser cutter. It seems that because the equal in shape magnets differ in their magnetic properties some kind of a ?superpole? develops when placed in a perfect circle, causing the sticky spot. Thus, to make the magnetic field really homogeneous and symmetric more adjustment of the magnets is needed which may lead to the structure appearing quite non-symmetric.
As an example you may take a look at http://video.google.com/videoplay?docid=2383887636280790847 where you can probably see that the magnets are not placed symmetrically on both sides of the ramp. The video shows a SMOT which only works if the magnets are adjusted in a certain non-symmetrical fashion. The shown construction, nevertheless, is still not optimized and needs more adjustment. In order for the SMOT to work optimally a lot of tweaking is needed and that does not necessarily mean that the construction will end up being symmetric. It seems that the essence of making a good SMOT (raising the ball to a greater height) and especially of making a closed-loop SMOT is to have a proper construction of the device which would allow for a precise adjustment of the magnets.
peter_schmalenbach
Quote from: Omnibus on November 17, 2006, 07:48:06 PM
Hello Omnibus,
thank you for your reply.
Please search in Google.com "Werner Heisenberg Magnetic Field Energy"  or similar.
http://www.google.de/search?q=Werner+Heisenberg+Magnetic+Field+Energy&btnG=Suche&hl=de&newwindow=1
Best regards
Peter Schmalenbach
Omnibus
@peter_schmalencach,
The only references to Heisenberg regarding the quotations in questions I was able to find were in:
http://www.datadiwan.de/magazin/dz0113e_.htm#impossible
and
http://magneticpowerinc.com/exec.html
These are websites, however, and therefore are unreliable as a source. Do you know of any peer-reviewed publication which might contain these Heisenberg?s words?
peter_schmalenbach
Hi Omnibus,
in this Artikel is noted:
Already around 1950, Nobel prize winner Werner Heisenberg (1901-1976) had said that it should be possible to use magnetism as a source of energy. He added: ?But we science idiots will never make it; it has to be done by outsiders".
More here, but in German:
http://www.google.de/search?hl=de&q=Werner+Heisenberg+Energie+wir+wissenschaftsidioten&btnG=Google-Suche&meta=lr%3Dlang_de
"Dazu geh?ren viele Ger?te, die mit bestimmten Anordnungen von Magneten arbeiten und bisher wenig bekannte Effekte von Magnetfeldern ausnutzen. Bereits Nobelpreistr?ger Werner Heisenberg sagte, es m?sse m?glich sein, den Magnetismus als Energiequelle zu nutzen, wobei er hinzuf?gte: ?Aber wir Wissenschaftsidioten schaffen es nicht; das muss von Aussenseitern kommen?. Dabei wird gem?ss Schneider entweder (a) mechanische Energie in elektrische Energie umgewandelt; (b) durch die Nutzung der Anziehungs- bzw. Abstossungskraft von starken Permanentmagneten mechanische Energie aus dem Magnetfeld erzeugt; (c) direkt elektrische Energie aus rotierenden Magnetfeldern erzeugt (hierher geh?rt die sogenannte ?N-Maschine?); (d) elektrische Energie durch periodische zeitliche oder r?umliche Variation von Magnetfeldern erzeugt (wie in der sogenannten ?Kromrey-Maschine? aus Genf); oder (e) es wird Energie aus dem Vorgang der Ummagnetisierung zur?ckgewonnen (dieses Prinzip ben?tzt z.B. eine Erfindung des Wiener Ingenieurs Franz Seidl)."
Peter Schmalenbach
