Fanner/Pseudo Solid Technology combined for overunity, LaFonte Group
Started by gammarayburst, January 07, 2012, 01:41:10 PM
gammarayburst
Broli,
Have you ever wondered why the two elements in a magnetic field stop repelling? The reason is the field between them is no longer compressed and the system has switched to attraction mode. This allows you to position an additional element to be pulled into the field between the two seperated elements.
Butch
gammarayburst
For all practicle purposes every phase in this system is positive useful work. A final configuration for production will be a very different layout, but will operate on the same principle.
1. The bar is closed so that it is in our Pseudo Solid configuration and moves the now closed disks into the magnetic field of the stator.
2. After the closed disks are centered in the stator magnetic field they are allowed to repel to the open position due to the fanner effect. This is positive work done by the magnetic field.
3. Now external disks are now allowed to be attracted into the space between the separated disks. This is again positive work done by the magnetic field.
4. Now the bar is a Pseudo Solid again and can be move with no work to speak of to an area of the bar length that allows the disks to be out of the magnetic field and the external disks can be removed with no work to speak of.
5. The bar now closes and the disks come together again the form a Pseudo Solid or solid in effect bar length.
6. The bar ends never come close to leaving the magnetic field of the stator because there is no need to.
7. The cycle is now ready to restart.
Thanks,
Butch LaFonte
gammarayburst
Quote from: broli on January 07, 2012, 06:41:31 PM
Can you link me to this video please.
Sure, I will look it up and post a link, it's dark and was done by our member Lawrence but you can see the bar being pulled in. Mark may have done one also and we are looking for it.
Butch
gammarayburst
Quote from: gammarayburst on January 07, 2012, 10:58:26 PM
Butch
This is to dark to see, we will have to make a new video.
http://www.youtube.com/watch?v=hDBBYvg5YDk&list=UUV6BqQ_hToPob2lfymlIYLg&index=9&feature=plcp
Low-Q
Quote from: gammarayburst on January 07, 2012, 07:16:03 PM
Broli,
Butch
That is a way to put it. The separation occours only under given conditions. If the magnet is relatively small compared to the two elements combined, the elements will not separate. I have played quite much with magnets in different sizes, and it appears to me that the elements will separate if the magnet is wide enough. The separation will find its equilibrium, the point where the attraction between the magnet an the elements are strongest.
How this position is suddenly switched to attraction mode, is something I quite not get...
Vidar
