Ghazanfar Ali Generator - Utlilizing trapped energy
Started by Ghazanfar_Ali, February 04, 2012, 03:14:30 AM
Mannix
Ali,
I would  assure you of  generous donations from most people here .................If the real light can be made to stay lit ...even if its a bit dimm.
Even 5 watts  would be a miracle.
back to work!
27Bubba
Hi to All here. I'm trying to understand Ali's device and few thing are not clear for me. Always been interested in electronics but life got in the way of doing it. So after I retired I decided to give a go. First other than VOM and ampere meter I don't have any fancy tool in my shop nor the knowledge how to use it... Can read schematic enough to get me in trouble ;D.
I attached schematic created by Ali and modified by Broli that I marked with areas that not clear/confusing to me. Could somebody kindly take look at it and explain in simple terms what I'm looking at?
One question I have where the "antenna" connect to?
Noticed two areas marked "L1" I presume one of them is coil and the other light bulb?
One capacitor (the smaller one) the voltage value is missing, is it not important?
Forgot to ask, Did I got the Mofset labelled OK?
Thanks..
e2matrix
@Ghazanfar_Ali  I think you will find Dr. Steven Jones (PhysicsProf here I believe) who is a former University physics prof. has a reward offered right now of some gold and / or silver coins (real $$ value) for any device that can meet some fairly simple overunity requirements.  You can find info here and a couple other energy forums if you look around.  It does have to meet some minimum requirements and the intent is to keep it open source so all people can benefit if I recall correctly.
27Bubba I think I can answer at least one question with reasonable certainty.  The two connection points on the left of the diagram are where you would hook up a signal generator or square wave signal input of some sort.  As far as the L1 etc.  One is a coil but the other ones are Light bulbs which he simply abbreviated as L1, L2 and L3 rather than Light or Load 1 etc.  It may have been clearer to label them as resistances or loads.  But it seems clear to me based on the description that is what he intended.  Not sure about any antenna but I see a ground symbol in blue at the bottom if that is what you are referring to.
Groundloop
Quote from: 27Bubba on February 04, 2012, 09:31:23 PM
Thanks..
@27Bubba,
No, you labeled the mosfet wrong. Attached is the IRFP260 data sheet that shows the correct pin configuration.
What is described in the Ali circuit is a voltage boost converter. The unloaded resonant frequency of the coil and capacitor
is approx. 2KHz. The 1mS / 0,5mS indicate that the function generator input is 1KHz. What is missing in the
simulation is the power input. The power input is over the 4700uF/50V electrolytic capacitor. Attached is a redraw
of the proposed circuit.
GL.
duff
Quote from: Groundloop on February 05, 2012, 01:56:47 AM
@27Bubba,
What is described in the Ali circuit is a voltage boost converter. The resonant frequency of the coil and capacitor
is approx. 2KHz. The 1mS / 0,5mS also indicate that the function generator input is 2KHz. What is missing in the
GL.
GL,
The 555 (or function generator) is running at 1KHz,  period is 1ms with .5ms on time.
As you say the tank is resonant at 2KHz but oddly the oscillations are at 1KHz
Included a scope shot from  v1_2.ms11 .
