Spring Screen Magnetic Engine
Started by vineet_kiran, February 18, 2012, 11:09:03 PM
vineet_kiran
Magnetic Engine using spring screen
Low-Q
Quote from: vineet_kiran on February 18, 2012, 11:09:03 PM
Wonder how the stationary magnet will affect the springs behaviour - how it actually feels like compressing and releasing the spring in a magnetic field depending on the other magnets position. I have rod magnets, lots of them measuring 70 x 5 x 5mm, with the polarity you have described - through thickness. I will try this setup, just to see what happens in practice.
Vidar
vineet_kiran
Quote from: Low-Q on February 20, 2012, 07:22:38 AM
Vidar
@vidar,
Wish you best of luck.   If you don't  mind kindly keep me or forum informed about the results and also the setup details (as done by you)
Regards,
Vineet.K.
Arrow
well if this is engine something has to turn if it is so try spiral maget setup to catch your spring magnet and ets, but first think how to run spiral magnet disk:)
Good luck
Low-Q
Quote from: vineet_kiran on February 20, 2012, 11:06:05 PM
@vidar,
Regards,
Vineet.K.
No problem. I guess it's fine to make a spring out of steel wire. The magnets and the wire is hidden behind all the kitchen and bathroom inventory in my garage (See the video at 32 seconds or so). To access it I must first set up the kitchen inventory where it belongs, but that will be done very soon. It depends a little on the electrichian to finish the outlets etc. first.
A small video of the place :-) If you don't like dance music, just mute the volume.... ;-))
http://www.youtube.com/watch?v=q_QKDq7XfB0
