TPU Revolution
Started by hartiberlin, March 02, 2012, 06:10:58 PM
ARMCORTEX
@ kent, I also wonder what Kaduci means, he is probably not the expert who built this most likely a messenger of somebody else. Best way to sustain a tornado is with 3 phase, I dont care if its ''ether'' or magnetic particles.
@ T-1000
Can I see this video ?How recently was this.
This could be a fun project and not too expensive, pretty much have the chips ready to go.
And theres always the slim possibility that I succeed. Otherwise I'll have a sculpture as decoration.
T-1000
Hi there,
Here is some crude experiment done based on Sergey's circuit to see if circuit works at all:
http://www.youtube.com/watch?v=QS9hqqwC75k
"To be continued..."  8)
e2matrix
Thanks for that document T-1000.   I'm not sure if it was available anywhere in English but I did translate it to English using a couple programs and Google translate.   Attached here in English.   Not sure I got all the pictures/diagrams in exactly the right place but they should be close.
d3x0r
Quote from: T-1000 on December 14, 2013, 07:40:50 AM
Hi there,
Should I share a theory about those bubbles of electrostatic?
(s/Should I/I'm going to, if you'll pay attention a little, and offer criticism.../)
If you have a pulse, you have a momentary (compression) wave followed by a (rarified) trough.  These represent themselves in induction as the rise and fall of current on the primary DC.... so there's a north and a instant south, in which is a packet of electrostatic... is this good?  Maybe not... really I think my marks on good/bad resonance is actually both bad, and somwehere in the middle where the field is also intersecting the winding is better.  So having a gap beween the center and the pickup winding would be better... (a aircore, winding, aircore, perpendicular winding)
Daniel Nunez's coils do this but cross-hatched-wise... (I dunno I think he's shorted some windings that he can do better)
Resonant gravity field coil
http://www.keelynet.com/gravity/gravity3.txt
Power requirements are ridiculous for that tough...
but it's a central flat coil in a circle surrounded by a toroidal wound coil...
Jdo300
Hi there,
Hi T-1000,
Thank you for the update as I was very curious to see how all of this has been progressing since your original posts. I can't understand Russian but wanted to as you if the man in the video mentions anything about the prototype putting out pulsed DC? Even if it has a COP < 1 at this point, it would still be encouraging to know if it is exhibiting any of the claimed effects.
@All,
I did a rough translation of the PDF file (using Google) and also included one of the circuit diagrams which were translated into English as well. It is attached below.
I am also working on a Data pattern generator board which uses simple dip switces and logic gates to create the pulse pattern shown in the PDF. The board will be able to be clocked from a function generator up to a max clock speed oh 20 MHz.  If there are any other replicators out there who are interested, let me know and I'll keep you posted once the design is finished.
Thanks,
Jason O
