Centripetal Force Yealds Over Unity
Started by MoRo, March 05, 2012, 07:22:17 AM
DreamThinkBuild
Hi Kator,
This is an interesting robot design.
http://www.youtube.com/watch?v=kNM2MiyZ5fw
I like how the arms fold inward on themselves. This design could be attached to a flywheel using a gyro sensor and weights at the ends. If four motors are used you would only have to activate the one in the 12:00-3:00 position. The arm would push the weight out at the 12:00 position than pull it back in as it nears the 3:00 position. So each motor would be given a 90 degree quadrant to work in depending on it's orientation. Would be interesting to see.
zoelra
A Milkovic 2SO is NOT OU.  It may be break even at best (excluding friction and air resistance).  The paper presented in the previous link is not credible.  Read some of the comments.  To date there is not one credible, peer reviewed analysis of the Milkovic 2SO showing OU.  If OU was there, closing the loop would not be difficult.
However, the 2SO (non-Milkovic style) is still my chosen path of experimentation.
Kator01
  DreamThinkBuild  interesting design indeed. Thank you for this link. The problem with pequaide´s discovery is a practical
version or better prototype which is able to collect the kinetic energy gained when the steelballs have flung out and the main inner body hast stopped moving. How can we do this ?
I regard his discovery at that stage a scientific experiment which must be veryfied by scientists with focus in kinetics.
Kator01
lightend
Thinking about this design, or more specifically using centrifugal focre.
Couldnt you just get a funnel, cut away the bottom, put a spiral in the inside, spin it at a fast rate and let said force pick up the water and take it to the top with little effort (need to use water so a to keep the weight spread evenly and prevent extra work).
collect the water as it flys out the top and use an alternator on the waters return to the starting chamber, thus harvesting electricity). you could test the theory with a 1 watt motor spinning at xxx, and a 2 watt generator powering the motor, you would need to hand crank it to start then see if it can power its self, if it can, its o.u. if not.... you learn another way how not to do something.
tim123
Hi Lightend,
  this can be done with a simple funnel. No need for spiral vanes... There's a paper on it somewhere I read once...
If you spin a cone with it's tip in the water - the water is drawn up the sides by cenrtifugal force.
I've often wondered about the efficiency of this. The paper I read indicated it might be OU.
The traditional view, I think, is that the work done by the spinning cone on the water - to accelerate it outward - should result in drag on the cone...
Regards, Tim
