Thanks to ALL for your help!!
what is the easiet gravity wheel i can do i only need 2 kw
Started by theshiningeagle, March 22, 2012, 01:21:53 AM
AB Hammer
Quote from: theshiningeagle on March 22, 2012, 01:21:53 AM
im an architect and a researcher
im new here
what is the easiet gravity wheel i can start with
i only need 2 kw
What is your purpose for this build?
There are many designs out there, but none of them work. That is are you are looking for a working one? but there are several ones that make good design. You can look at the MTs that Bessler put in his book for inspiration.  Here is a link to see them. They are in lots of 20 so at the bottom you can click and go to the next set.
http://www.besslerwheel.com/wiki/index.php?title=MT_1-20
With out a dream, there can be no vision.
Alan
Here, maybe this will give you some ideas. I particularly like the one at 3:00 on.
http://www.youtube.com/watch?v=287qd4uI7-E
theshiningeagle
Quote from: johnny874 on March 22, 2012, 05:45:39 PM
  Eagle1,
What TK said is right. While it can't be gauranteed, the 4 weighted wheel might be the next simplest.
The basic idea is that the path a weight follows from top center to bottom center is longer than the path upwards.
The problem to over come is that the distance a weight advances radially on it's way down increases it's upwards travel.
The math can be done to show what might work. What is not understood is the time it takes for weights to shift relative to their upward and downward motion. This affects the amount of time a weight is in over balance and would be powering the wheel.
        Jim
edited to add; Eagle1, anymore, this is a skeptics forum.
thank you for you help have you made a one that works >??
theshiningeagle
Quote from: AB Hammer on March 22, 2012, 06:05:37 PM
man of-course im looking for a working one :D this is so funny
im not looking for concepts
and it will better if something u made it by ur self
...by the way there alot of this concepts but what type of them works ??
by the way do u know a program which have magnet ..factor and shielding tool factor
so i can try with it ....to make a magnetic motor ...like the troy one
till i successed and then make it in real life
theshiningeagle
Quote from: TinselKoala on March 23, 2012, 12:16:16 AM
u know what i was watching this thousand times i like it
and i tried to make that flask way ...but faild ..
i think no one succeeded realy in making that flask way
what is that green liquid
