quentron.com
Started by Philip Hardcastle, April 04, 2012, 05:00:30 AM
sarkeizen
Quote from: lumen on December 27, 2012, 11:17:36 PM
Ok....whatever you say. No tech, your no value to me.
I suspect that this is just some face-saving way to excuse yourself from the discussion.  Again if you READ MY POSTS you'll see that I do discuss more than people but people like YOU don't want to talk about those things.  Was my metaphor (taken unabashedly from V for Vendetta) about looking in the mirror too difficult?
If you're being honest here, which is doubtful then what could I possibly discuss with someone who doesn't know how to read?  At least in this scenario, perhaps if we met in person I could use visual aids or perhaps put on a little play or puppet show to explain things to you.  Otherwise we are at an impasse.
QuoteIf you talk of concepts or ideas or theory, we talk to high class people.
If you talk of money and finances and investments, we talk to middle class.
People who talk about other people, are trying to pull themselves up or drag others down. (bottom feeders either way)
Drastic oversimplifications are handy aren't they?  With them you don't need to actually intellectually engage on an issue. You can just look at a list of a few simple rules and then POP your little brain need no longer worry about nagging questions.
Considering that all three of your rules are an example of someone talking about People - doesn't that mean you're - by your own logic a bottom feeder?  Just sayin'
Bruce_TPU
Hi Lumen,
Trying to talk to Sarkeizen is like spitting in the wind.  It is best to ignore.  He is overly impressed with himself and will not listen.  I have stopped reading his posts.  Let's all just move the conversation without him, and if he responds, ignore said response.
Cheers,
Bruce
lumen
Quote from: Madebymonkeys on December 28, 2012, 04:15:06 AM
He has been asking questions throughout, it was only (really) you who decided to start an argument!
I gave up asking questions when it was clear that nobody could really answer them - sarkaizen has some good questions, why not 'save face' and respond with answers?!
I guess even if the major questions cannot be answered (and they haven't been) then at least you are keeping this thread at the top of the list!!
Yes, you are correct! It always takes two to argue.
With that I must say : Sarkeizen my friend, all we do is argue anymore, So I'm leaving you.
Madebymonkeys
Quote from: Bruce_TPU on December 28, 2012, 01:25:03 PM
Hi Lumen,
Cheers,
Bruce
There is no conversation, just trolls having a pop at people with sensible questions!
This whole rant appears to have been started by people asking technical questions and discussing doubt about the whole quenco principle!
How about rewinding a few posts and trying to answer some questions?!
lumen
Quote from: sarkeizen on December 24, 2012, 01:03:17 PM
Dude, I've made two points.  One Philip agrees with - that he sucks at management - which of course should imply something about his next deadline and the other he's been unwilling or unable to formulate an answer to - which was that he's violating information theory (and probably computational complexity theory)Why not just talk about all of the shortcomings of Philip and his hypothetical device?   Unless you have an agenda for keeping free thought down!  Philip doesn't even have a single Quenco - it's hard to call this a technology in that sense.
OK, Rewind:
Do you see any real questions in there?
