How To Build A Bessler Type Wheel
Started by johnny874, April 06, 2012, 01:46:42 PM
johnny874
  @All,
I found an online converter  :D
The wheel I am building rotating at 60 rpm could produce 25 watts of
power having 2 lbs. (.9kg) of over balance.
With a larger wheel have 22 lbs. (10kg's) @ 6.5 ft (2 meters) and rotating
at 20 rpm would produce 400 watts of power.
I can see about using an axle/hub assembly that could be changed out for
one that could power a small generator.
Maybe I should thank Mr. Wayne. Really wouldn't have been concerned
about power output if not for his claims.
        Jim
http://www.magtrol.com/support/motorpower_calc.html
Rafael Ti
Hi Jim
Unfortunately your converter does not convert kilograms of gravity into Watts...  :( , does it?
How are you doing after surgery? How is your work going?
I think I've found a concept ensuring the weights to move on perfect path...
This is a path we actually need.. one of the lower quartercircle of wheel.. left or right depending on direction of rotation.
It is possible to achieve it in easy way using wheels and also... together with a good timing of dropping weights.
All the best.
johnny874
Quote from: Rafael Ti on May 31, 2012, 03:47:56 PM
Hi Jim
All the best.
  Raphael,
If you know the distance from it's axle, then you can calculate torque. I'm not literate in the metric system as to what most people use for force.
In the U.S., foot pounds are most common. I can see about finding conversions for metric/U.S. values so everyone will have a common basis when force is discussed. You know, something they can relate to.
On Saturday, I am going to make a video of 2 weights. One will be at the level of the axle and the other at bottom center. I did this before and got almost 90 degrees of rotation. Maybe I'll get similar results that I can show you.
See my 1st doctor tomorrow. If all goes well, I'll have one last surgery next Friday. Then I'll be able to enjoy our hobby that much more  :D
        Jim
johnny874
  @Rapheal,
You got me to realise something. 40 inches (what I am working with) and using 2 pounds of weight
is close to 1/2 Nm or Newton Metre of force. That would be 1 kg @ 1 metre (1 Nm or N-m) and
1/2 Nm @ 60 rpm would generate an immpressive 3.14 watts of power. I think it's funny that with
those numbers that watts is close to Pi which is 3.142 etc., etc.
I just ckecked and it seems like that is the relationship between watts and radius if calculated @ 60 rpm.
Now we have a simple method of understanding how many watts of power something can generate.
        Jim
johnny874
  @All,
It will be a while before I can do anything meaningful with this. If I take shortcuts, then it wouldn,t be worth it to me.
I might modify the 4 weighted wheel. That is something where different configurations can be tried to better understand acceleration.
              Jim
