How To Build A Bessler Type Wheel
Started by johnny874, April 06, 2012, 01:46:42 PM
johnny874
Quote from: Rafael Ti on May 31, 2012, 03:47:56 PM
Hi Jim
Unfortunately your converter does not convert kilograms of gravity into Watts...  :( , does it?
How are you doing after surgery? How is your work going?
I think I've found a concept ensuring the weights to move on perfect path...
This is a path we actually need.. one of the lower quartercircle of wheel.. left or right depending on direction of rotation.
It is possible to achieve it in easy way using wheels and also... together with a good timing of dropping weights.
All the best.
  Raphael,
Hope you like this video. it's pretty basic, it shows one weight accelerating another one.
What might be of interest is it's efficiency. I'll be able to make some more videos showing
some of the principles behind Bessler's wheel. At the same time, someone might see
where those same principles could be used differently.
With what the video shows is the basic relationship between f (force) and (=) ma (mass multiplied by acceleration).
In a wheel, weights will need to be rotated and understanding how f=ma applies will help to understand
how much force (energy) might be needed and about how much work the wheel could generate (free energy).
        Jim
http://www.youtube.com/watch?v=KOkj0czYG58&feature=youtu.be
FatBird
Here are some that work.  The SELF FLOWING Flask could be SCALED UP
to power a Water Wheel TURNING a GENERATOR.
FREE POWER 24 Hours a day, FOREVER!  How much more SIMPLE can it get?
http://www.youtube.com/watch?v=287qd4uI7-E&feature=channel&list=UL
johnny874
Quote from: FatBird on June 06, 2012, 02:53:52 PM
FREE POWER 24 Hours a day!  How much more SIMPLE can it get?
  FatBird,
I'm just wondering if you're manipulating it some how. The reason for this is that
with static heads, the total volume doesn't matter, only what is above the tube.
  All this means is that the levels of the flask and the tube should be at the same level.
Of course, with Bessler, I think in time you will understand how he used hydraulics
differently and in reality, his wheel is ingenious.
        Jim
johnny874
   FatBird,
  Is that your wood working ? What I can do is build a section of the wheel
to demonstrate the principle itself. One thing about it is I will be giving away
how to use warped boards without doing to much work. This would probaly
be the most difficult part of the build.
Who knows, maybe you'll find it interesting enough to maybe try yourself.
I mean if you are a part of that group, you might find this a bit more interesting
than other people and possibly worth trying.
About my health, I'll send you a pm of why it's such a problem and why right now
I'm not really interested in doing much.
                                                               Jim
FatBird
Johnny,
Thank you for explaining about your health problem.
I hope everything goes perfect for your recovery sir.
