electrolysys with horizontal plates
Started by Walter Hofmann, July 02, 2006, 03:56:31 PM
hartiberlin
Hi Walter,
try to use a small 0.2 Liter plastic coka-cola bottle turned around and filled
with water and measure the time it takes to fill it with oxyhydrogen gas.
Let the gas bubble in there via a hose under water and
see how fast the bottle will be full of gas.
Like this movie:
http://grmhosting.com/img/galleries/videos/hproduction.mpg
But be more cautious than this guy !
He is holding a gas bomb in his hand !
If this would have exploded, he would have probably
lost his hands !
Use only a very small  PLASTIC bottle, not more than 0.2 Liter
or less and don?t stand near it, when you do the experiment !
hartiberlin
P.S: It would be better, if you "suck" the gas out of the electrolizer
with a small pump, so you will get much more gas out of it in faster time
as the electrolysis is much dependend from gas pressure and
a low atmospherical pressure is good to get more gas out !
Walter Hofmann
Quote from: hartiberlin on July 04, 2006, 07:38:31 AM
Hi Walter,
Like this movie:
lost his hands !
hallo stefan,
thanks for the tip I will try it.
Here is a picture of the horizontal plates how it is build. with the next post I send a realtime video from the cell, I hope I can do this.
greetings
walt
Walter Hofmann
Quote from: hartiberlin on July 04, 2006, 07:41:17 AM
hallo stefan,
here is the video from the cell, but the audio has the terrible noise from my A/C system on it and I can not get it off, maybe you can do it or everybody should turn off the audio. this is in real time from start. pretty close to the end there could be seen that the cell still generates gas untill the voltage goes below 1.3V, this was verry interesting to me. The voltage on this setup is straight 12V DC and the current is around 10 A.
greetings
walt
I can not get it done it allways brings a timeout message, I will send it direct to you stefan.
Landor
Try using a hexagonal shape mesh construction. Most of all insects use this for construction and lift in fact a multitude of applications. It seems that it is a major design in most of creation.
Interesting that Nano technology has picked up on it.
