Accelerating wheel modeled under real world conditions - could it be?
Started by AquariuZ, April 11, 2012, 08:45:05 PM
DreamThinkBuild
Hi AquariuZ,
I've tested that design in the video a while back and it essentially becomes static. It won't be running the 5kw generator head.
I came up with another design that would push/shift the center of gravity based off the rubber band heat engine idea, replace the heat with the force of magnets.
The shifted weight must be able to overcome the force of the sticky spot as the magnets are traveling up towards the pushing magnet. Not sure if this can be offset with a flywheel, smaller/angled pushing magnet or using the curve of a diametric magnet to lessen the effect. I haven't had the time to build it to see.
Based on the principle of the rubber band heat engine.
http://www.youtube.com/watch?v=dBXL93984cQ
AquariuZ
Quote from: ruin41 on May 09, 2012, 08:09:16 AM
When i started reading this thread i thought this looks promising. Before doing anything serious on this i would highly recomend a pendulum test as this is what your washers are. In my opinion the laws of physics would dictate that for every action there is an equal and opposite reaction and for each casue there will be an effect. My belief here is that the action of the washers being atracted to the magnet will result in an equal and opposite reaction to said latching that will reduce the weight of the washers and thus negate the weight advantage you are trying to achieve. Just as an asside this is kinda pointless as it can never go fast due to centrifugal force throwing out the whole thing eg every washer pendulum and so if you were to scale this up to a usable level say the size of a feris wheel with 1000lb weights and you were actually able to displace one 1% you would have a total force of 10lbs of usable work from it. The vid with the ball and wheel is awesome but that too is never going to scale past a toy.
Yes, that´s why I am thinking one way clutches for the pendulum (see above).
AquariuZ
Quote from: DreamThinkBuild on May 09, 2012, 11:27:04 PM
Hi AquariuZ,
Which video/design do you mean? (the one you tried and turned out static)
About the rubber bands: I really like your idea!
I am actually at the moment looking at a good way to make a decent pendulum that can only move to one direction (using a ratchet system). I have tried some things using a bicycle wheel and it is hard to attach the weights just the way I want. Still, I could see an effect.
Nope, if i want to really test this I will have to build a real wheel and either use pendulum weights and a magnet or pendulum weights and a small ventilator with spider fingers to displace the weights.
In theory two weights would be enough.
