High RPM to Low RPM, Motor-Generator: Public Discolsure - The Real McCoy
Started by bradagilah, April 15, 2012, 04:53:16 PM
bradagilah
Quote from: citfta on April 16, 2012, 07:52:14 PM
Sorry but this guy is mixing  up Full Load current with output power.  Yes the current is reduced if the motor is 3 phase instead of single phase.  But if a motor is rated for 5 HP that is the total output at the shaft not the output of one phase.  I worked as an industrial maintenance electrician for 30 years.  This guy needs to go back to school.  Just go to any motor manufacturer and look at how motors are rated by them.  Wikipedia also says motors are rated by the power at the output shaft.  I didn't take the time to look up the actual data on generators but I am sure the rated output of a generator is for all phases combined also.
Respectfully,
Carroll
No.  Your mixing up what I wrote, with what ever is going on in your head.  That's a baseless statement on your part to say current is reduced, if the motor is 3-phase over single phase.  What exactly do you maintain, light switches and electrical outlets?  Some of my personnel, have been trained by the Navy, and they are the men, who keep the birds up in the air - when the electronics of an aircraft fail, they fix it.  Try again sherlock, motors are CATEGORIZED by the power at the output shaft - motors however are rated based on many NEMA specifications that are on the motors name plate.  You didn't take the time to do proper research, and now your talking out your ass.  Go grab a text book and learn how generators and motors are rated and categorized.
Peanutbutter29
one_christian_warrior
 GEM
God’s Electricity Machine
self generating electricity machine
this is relatively easy to build
and should be very cheap
built out of junkyard parts even
to reproduce in any scale, any voltage,
(I happen to be disabled + unable to build this)
This should be very cheap to build
I know that it seems too simple to work
but I proved that it works with my electric wheelchair experiment
if you put DC power into a large wheel turning very slowly
and then take AC power out of the small wheel(s)
that spin hundreds of times faster
Help me, help others, help themselves
we could start a new + improved industrial age
one that not only cause little mess of pollution
like in the original industrial age brought with it
This one could actually help our environment
by producing costless to run air and water filters
we could possibly have every back yard mechanic
coming out with very specialized adoptions
for this free energy box, cube, machine
And how, you might add, did I come up with this,
I didn’t, it was God,(Holy Spirit) Who showed this to me,
When I ask Him to show me how I might help
The Saints survive the soon coming great tribulation
how to get electricity to generate itself.
I have stumbled upon the
PERPETUAL MOTION machine
Yes,,,,, and even better than perpetual,,,,
,,, this machine actually makes its own power,
as in â€" this system uses passing time to gain electrical energy,
yessss,,, we can let electricity generate itself,,,,
No more dependency on OIL, and the middle east oil supplies,,,
and the world says,
Now hold on just a moment,,,
I know that this is not a true example of perpetual motion,,,
Because of bearings alone,
or should I say, the fact that they will wear out eventually,
That is why I added the word "machine" afterwards
This is a man made machine,
Which only mimics perpetual motion,
As it continues to run, seemingly forever,
Producing electricity as a side effect, (bonus !!!)
This is a gift from God,,,
As He has shared this with me
To share with the world,
I do not know why my Lord has chosen to share this with me, at this time,
Maybe it is because my Father knows that time is short,
and He wants to show all mankind,
just one more way that He is Love,,,
God has shown me,
a way of gaining free energy,
seemingly from nothing,
This came to me when I was over visiting at the park,
I was thinking about how electricity worked,
and how my electric chair had the ability to charge itself,
on most any type of downhill run,
(as it uses an electrical breaking system)
I don't know if you know anything about me or not,
but learning new things is one of my greatest pleasures,,, (especially about God)
and,,,,
When investigating how things work,,,
I always have to push the limits,,, lol
not only learning how things works,
but then tinker with trying to improve them,,,,, lol
I went with the idea of a ten speed bicycle, (something that I knew about)
Where I wanted to go uphill in tenth gear, (least rotations of the pedals)=motor
and then downhill in first gear, (most rotations of pedals)=motor
so, I would go uphill at full speed,
and then downhill at slow speed
So,,, now I had something to experiment with,
now I had measurable tests to do,
(I had to set my chair to max torq=1st gear and max speed=10th gear)
I started off with a low battery, (so that I did not have the power to drive all the way up)
driving up a long steep hill at the park in the full speed position, (tenth gear)
(until my chair would not go any further, as my battery was dead) it was a long run
and then going back down the hill in slow speed, (first gear) = higher multiple factor
(not super slow, as I had time limits = only 4-6 hours of sunlight left)
Then I immediately turned around, and went back up at full speed,
And guess what happened,,,,
I could travel twenty feet higher up the hill,
so, I had a net gain of electricity,,, (a blessing)
Logic and common sense says,
that you will have energy losses,
do to heat from friction if nothing else,
causing you to not be able to make it as far up the hill,
the second time you drive up it,
Well, I first thought that this might just be a strange happening,
so I did it again and again, doing it three times,
each time gaining twenty more feet, up a steep hill, (60 feet total)
Not only did I do it three times that day,
but I later thought that this went against logic, (I must have dreamed it)
and I did the whole experiment over,
with the same electricity gaining results
I know that there are inner workings of the motor + drive system,
that I have not even roughly looked into,
to find out why + how it works like a 10 speed,
Sorry, but I have no time to color + shade in this drawing,
I could only give you this rough sketch,
and let others get the enjoyment of coloring in the details,
may this bring you at least some of the thrills that I have experien-ced,
when I was showed this amazing reasoning,
Please read (Luke 18:29-30)
Someone could easily build a self supplying energy producing power supply,
With a 12v battery,(not needed) two motors, a small and large pulley, and a belt,
You connect the motor with the big pulley up as a power in, driver motor,
And then connect the motor,(s) with the small pulley to be used as an output
When you put power into the drive motor,
You get out a multiple of this power, (on each of the out generators)
Compared to the size difference of the drive motor, (large pulley)
And your output or generator motor. (small pulley)
I will be emailing this to all of our Canadian government
as well as to as many news services that I can
to help get this new technology out in our world fast
and start helping our environment
believe me,,, I know how unbelievable this sounds
I had to repeat the experiment three times
to get a better understanding of how to believe what I was seeing
and then I even thought that I must have dreamed it
and had to repeat the exercise the three times again, about a week later
All I need is, for one person to take this serious
and to actually take the minimal time to build this contraption for me
I feel that this will take off like wildfire
as soon as the world gets a chance to take a look at this
THIS IS A FREE FOR ALL
Perpetual Motion machine
Just think of it, We could all have our own stand alone, self powering electricity generators, with only the initial cost of building it,(could be made of junkyard parts). These power manufacturers could be producing a seemingly endless supply of free electricity, all for the cost of upkeep. It is easy enough to build, as all you need is a twelve volt battery, two 12 Volt motors,(one DC + one AC) one large pulley, and at least one small pulley, a belt that fits the pulleys, and the hardware to put these parts together.(nuts + bolts + framing to mount on). This could even be done with 120 volt motors, to produce power for yourself, or to use as an income when you sell it back to the power company.
((along with electronics, such as an AC and a DC motor, a battery=(not needed), wires, a bridge rectifier and a voltage regulator, of equal voltage))
((all of the electronics to run this could be easily built on a simple proto-board))
(you might even be able to use any voltage motors - even 120 Volt)
((taking your output from the ac motor leads))
(((as I don’t think the battery is a necessary component)))
It is a very simple mechanism in its workings, as it works by putting power into the motor with the big pulley attached, and you take power out from the motor-(generator) with the small pulley attached. The output motor, or several motors even, the one(s) with the small pulley attached, rotates a lot faster than your input motor,(more speed = increase in power). There is a belt connecting the two,(or more) motors together, that can be as small as you want, depending on if you required size constraints, or as large as you want, to accommodate multiple output generators,,, like in our petrol fuelled power stations, they could be easily modified to run on their own power. I cannot be sure, without having results from tests, but I think that we can gain more power, with every output generator that you add with a small pulley. But there is a warning that I have to give you, of a possible haardous flaw in this free electricity generating system.
CAUTON,,,,,,,,,,
If this system is allowed to run freely,
without having any outside drain of power,
this system will overcharge itself,
and may even explode.
So, please,,,
be careful when experimenting with this mechanism.
Maybe this should be called an Energy Multiplier,
as you always need at least a little power,
to generate the greater amount of power.
I later found a site on the web that said
That if you published something on the web
But did not choose to patent it
You would open it up to be used freely by everybody
So,,, this was the choice I decided on
To put the plans out on the web for all to use freely
Why not let electricity generate itself,,,,,,,,,,,,,,
Benefits to humanity:
- To be an effective way to decrease our negative environmental effects on our earth,
- To be able to give free electrical power to all people,
- To greatly reduce our oil dependency,
- To give the Middle East less power,
- To lessen the chance of our need for oil getting us into another war,
- To put a needed boast to our economy,
--- by creating many new items to manufacture and sell
I want to get this out in the market fast,,,
so that there are many of these around,
for everybody to get their hands on,
so that we can all have free running electric cars
As well as having their own 120 volt power supplies
there is a full diagram of this device at
http://free-energy.yolasite.com/
how about energy multiplication
where you have two equal voltage motors
one is DC for input
which has a large pulley attached to it
the second motor is AC
on a much smaller pulley
this way your driver motor only turns a few times
while your output motor spins hundreds of times
you get a multiple of power out
compared to the power you put in
you run your output motor, (or multiple motors)
through a full wave bridge rectifier and voltage regulator
to power your DC input motor
and take AC power straight off your AC generator
You could start this system running by giving the big pulley a little turn
We could all be putting power back into the system, by building a rough Perpetual Motion mechanisms out of junk yard parts even. I would imagine that the manufacturing industry would quickly come out with these mechanisms in all sizes, so that people could easily supplement their incomes by selling power to the power companies
PLEASE let us act FAST
Let this be a Gift to all mankind
this energy multiplication system works
it does not work on electronics calculations
but works on large speed differences
between your input and your output motors
this major multiplication of rpms is great enough
to negate any loss due to friction losses
because of the vast circumference difference
between your input motor (extremely slow)
and the output motor (extremely fast)
ok, lets just keep talking about how this wont work
never really even trying to build it, (it is too far fetched to believe)
and let this blessing to mankind be missed
I have a great idea
If someone could build this device
on a circuit diagnostic program
they could both prove that it works
and we would have a video of it to put on utube
let’s change the world
Respectfully,
Carroll
The discussion was not about the HP rating of the motor, all of that adds up. We were talking about the output rating of the generator which does not have an HP rating only a Watt rating. I agree with bradagilah on this one, please be constructive if you intend to post
Edit: Tried mailing ginlong about the output rating of the gen but the mail keeps bouncing back, something is up with their mailserver, that's a bummer.
citfta
Hi broli,
Please read what I quoted from his post again.  He clearly says motor nameplate.  The reason I used HP instead of KW is because HP is the way motors are normally rated.  To convert this to KW simply multiply the HP by .746 and this will give you the KW rating.  Go and look up how motors are rated and you will see as I said they are rated for the total power at the shaft and not for each phase.  This will make a big difference in your calculations.   And just for the record I also have training in electronics and electrical power.  I graduated with a 4.0 GPA.
Quote from: bradagilah on April 16, 2012, 05:04:30 PM
Just as with a polyphase motor, the rated output on the nameplate is just for a single phase...  So a 5kW 3PH generator head gives you 5kW per phase (and be careful how you interpret that statement, because there is more to that...).  All generator and motor manufacturers, use this standard on the name plate.  The FL (full load) information, on the motor's nameplate, is not indicting the polyphase output, it is indicating the output of a single phase, and that is why you had to multiply the rating for a single phase by the square root of 3.  The square root of 3, has to do with the power lift, from the interacting phase angles - 5kW would not be 15kW, it is 8.65kW.   If that doesn't make sense to you, it's because you don't have the prior training to interpret the information.  I could be misleading all of you, and you wouldn't know otherwise because of a lack of knowledge in this area... But fortunately I am not.  All the information I am having to explain to all of you, I would not have to explain to someone who already is an expert in the field of motors.  I am not making this information up, it is inside of the University text book.
You don't necessarily need to apply the squ3 lift on the motors input in your math if your only working with three phase and you already know this..., but if your going to do that, then you have to do it on the gen heads output as well, so that your math is accurate.
Respectfully,
Carroll
