Bessler Wheel Theory
Started by johnny874, June 13, 2012, 01:55:16 PM
johnny874
   @All,
Since I believe Bessler used 8 pumps working sequentially, it is a mechanical device.
The attached picture is a basic pump which would show what I believe Bessler was
aware of.
The tube I will use to hold water will be about 3 inches wide and 11 inches long. The top
will open to 2 inches with the bottom being closed. I figure if it's close to 12 ounces of water,
then will find out what happens when a 1 pound weight on a long lever drops.
I'm thinking the water will shoot up and out of the tube. The tube will extend to the top of
the pump set up. I may need to add bracing to hold the tube and make sure it doesn't get and kinks in it.
While basic, what Bessler had to work with wasn't that advanced, it was more a matter of what he did with it.
edited to add; if the top opens 1 inch and is 2 1/2 inches wide, times 11 is about 8 ounces.
1 lb. at a 3:1 ratio will pulverize the water.
johnny874
Quote from: microcontroller on June 13, 2012, 02:35:19 PM
Dude whatever makes you think they had pumps back in those times?
We are talking 1700 here.
What makes you think he had any means to confine or seal water in his wheel?
He cannot have had things available to us at this point.
If his bessler wheel contained any water it would have leaked out in those 54 days that it ran because he had no means of sealing or enclosing the water in his wheel.
The bessler wheel did NOT cointain any water.
Leather was used for bellows. If something is air tight, it is water tight. He modified the design. They had means back 4,000 years ago, why there was ship building.
http://www.youtube.com/watch?v=o_3dF5bIJ_s&feature=youtu.be
johnny874
  micro,
Am going to work off line. It is a lot of work.
johnny874
  A better video showing the water shooting out of the pump similar to a Bessler drawing
where an Archimedes pump has a similar discharge.
http://www.youtube.com/watch?v=h33LqXPCdV4
edited; first video, weight landed on a stop. 2nd video, better function.
http://www.youtube.com/watch?v=JOl2dJaavS8
definition of pictogram
http://en.wikipedia.org/wiki/Pictogram
