Bessler , Karl I! The fat lady is gonna sing , haters bring it I'm not skeered .
Started by christo4_99, June 28, 2012, 06:38:25 AM
johnny874
Quote from: ace569er on February 19, 2013, 10:00:31 AM
Possible. I have not been able to see the bottom, very well. I know the pendulums themselves have magnets on them. Still lost with the central spring. Were does that energy transfer go? The overhead magnet is only connected to the  spring and following overhead magnet...
  acer,
have taken a closer look at the thing. the central spring seems to only work with the magnets above the bearing.
There is a tab/spring the bearing rolls over which causes the pendulum to swing. Apparently the magnet on top is supposed to tilt the central spring in that direction. Then the swinging of the pendulums add a different torsion to control the tilt of the ebarings track.
It seems the pendulums are connected through non-local behavior. This simply means that as a horshoe magnet drops because the bearing just rolled over it's tab and that the next pendulum will swing in the opposite direction because it's effected by the magnet which seems to pull it down with it. Of course, if 2 pendulums are swing away from each other, does this increas3ed motion equal to sufficient force to tilt the bearing's track in that direction ?
What you should take a close look at is where the ebaring is on it's track while the 2 pendulums are swinging in opposite directions. The bearing is basically over one and rolling towards the other. Could be how the tilt is maintained.
Still, think my critics could have made these observations. Will need to stay off line, kind of tired of being bad mouthed for having schooling in engineering.
ace569er
Curious how long did you school for? Also what type of engineering? I'm on my second year of mechanical engineering. Personally they have shown me little I haven't already learned myself prior. Waste of money.....for a piece of paper. Anyways I wasn't trying to yell at you, I just couldn't see how you didn't see how it was defying thermodynamics, and you were to concerned with newton's laws.....sorry
Vinnystvincent
Yes the mags are pushing and pulling.
I tried this a long time ago and it seems like you can only get around 10 minutes of moving before it finds a sweet spot to settle into.
johnny874
Quote from: ace569er on February 20, 2013, 09:25:27 PM
  propulsion engineering. I guess with me, I got used to looking at how the system functioned as a whole.
take4 out one piece of the system and it would quit working. you know, like the boilers, the steam driven turbines, the steam driven pumps, it all worked together.
murmel, if you watch closely, the pendulums have a counter weight that the horse shoe magnet also pulls down with it.
