Simple to build isolation transformer that consumes less power than it gives out
Started by Jack Noskills, July 03, 2012, 08:01:10 AM
e2matrix
Still looking through my junk piles for some 1:1 isolation transformers.  It just occurred to me that some of the old computer UPS units probably have 1:1 transformers in them as they pass through 120 AC when not running off the battery.   Getting ready to pull a couple apart to check it out.  As I've gotten some cheap at garage sales this might be a good source for higher power 1:1 transformers since they seem to be quite expensive from sources I've seen so far.  I'm not sure on this but will post later what I find.
   Old Tripp Lite had 3 transformers but no luck with 1:1's.  Still a few more to check out.   Now I'm thinking old high end audio equipment may have some.  got some of those laying around too.
Groundloop
Quote from: e2matrix on July 06, 2012, 03:19:01 PM
E2,
All switch mode power supplies such as used in computers has a 1:1 Ferrite transformer at the AC input line.
The transformers are small but could be used at lower wattage for testing purpose.
GL.
JouleSeeker
Well, earlier today I ordered two isolation trafos that I found on-line --  on the right in attached.   $11.66 each, from Allied Electronics.
The one on the left, toroidal, is also an isolation trafo and almost did that, but cost $18.11 each... maybe next time, but soon I'll have the two little guys (1.7lbs each actually).
  I was surprised I could get these at such a low price.
Thanks again, Jack!   lots of fun and adventure thrown in...
casman1969
Single or double transformer arrangement requires higher impedance primary than secondary? Is this correct?
