Thanks to ALL for your help!!
please reproduce
Started by Murfedit, July 18, 2012, 06:09:55 PM
Murfedit
There is no moisture at all. And my dvm does 0 out.  I have non digi for measuring resistance, amps and such. And an oscilloscope too. Not going too wax intellectual either over semantics. Just want too know if you get the same results burn some magnesium use the ash as the medium between electrodes and share your findings please. I am not here to prove anything and will continue doing my experiment regardless. Thank you for your time.
Murfedit
Very cool stuff. I have to get some eggs and try it out. I like the natural approach. Keep the good work. Inspiring many I'm sure.
Murfedit
I started to add white glue to the ash to make more of a glue cell type battery so now there is moisture added.  But it is still just magnesium ash after burnt, white elmers glue, anode and cathode. I use copper and magnesium ribbon as electrodes.
So i conforms with a normal battery type sort of. But you can get small readings out of just the dry ash when pinched between copper and magnesium ribbon.  And i apologize if i came across rude.
Im just very busy
