need help with volts and amps
Started by Grone, August 22, 2012, 08:02:09 AM
poynt99
GL,
Have you built and tested this?
Does the 100k resistor get warm?
Groundloop
Quote from: poynt99 on September 02, 2012, 11:42:57 AM
GL,
.99
No, I have not built and tested this circuit. But I see no reason for it not to work.
If the resistor gets warm then he must use a higher wattage resistor. The resistor
value (Ohm) may also be changed in a practical circuit build. This was the simplest
circuit I could think of, avoiding transistors, mosfets, thyristors etc. At 2000 Volt DC
a very narrow band spark gap may also work, thus eliminating the transient protector.
This circuit has so few components that it may be worth a try.
GL.
Grone
Great! Many thanks GL !!!
will put the circuit together and give it a try!!
