FDM - flux displacer motor by Igor Knitel (Perihelion Labs)
Started by wizkycho, August 27, 2012, 04:36:27 PM
wizkycho
Hi all !
can somebody supply me with or recommend where to order:
laser or water cuted silicon iron sheets (low frequency 50-60Hz - transformer grade material)
if sheets are thick 0.5mm then need 50 sheets
if sheets are thick 0.3mm then need 75 sheets
dimmensions are on attachment
I'll send vector file format for CNC, not jpg, if needed.
anybody !
kind regards
Igor Knitel
lumen
This is an interesting design in that it appears to meet all the right field conditions. Where are all the cad plans with the details?
I usually like to reverse the conditions in the two rotor systems to investigate the operational problem so here is another concept.
Suppose the outer rotor is stationary and the inner rotor is only for control and can rotate about 90 degrees and the STATOR is now the rotor.
Do the same conditions exist for operation? This design would require no input and is exactly the same provided there is no drag on the input rotor as stated.
e2matrix
Interesting but I think you are over a lot of people's heads with this and well beyond most peoples capabilities to build a unit like this.  If you believe it will work and have the ability to build it then that would be great.  I think there are a few people here who could analyze this to see how well it might work.  If you have more detailed plans or pictures that may help get more comments.  We would all love to see a COP >15 or even great than 5 motor.
MT
Hi wizkycho,
I like the idea. Magnets in inner rotor create and control field intensity bottoms in stator steel while outer rotor follows the field peaks. Indirect 1:1 magnetic coupling.
Construction does not look cheap to me. Inner rotor would probably need custom made magnets. Stator ring needs to be sufficiently big to accommodate inner rotor. Definitely a >100â,¬ build.
regards,
Marcel
