Richard VIALLE's new theory about negative mass and overunity
Started by Pascuser, August 28, 2012, 07:03:17 PM
Pascuser
Same experiment here:
http://www.conspirovniscience.com/forum/index.php?showtopic=922&view=findpost&p=24375
The amplifier used is the same used by Richard VIALLE when the looped circuit was performed (self powering device, recharging battery used to power the device while outputting 10 watts constantly during months). This amplifier was not working anymore since early 2008 because the transistor burnt in an accident, Richard VIALLE could not have negative power again with new 2SC2312 Mitsubishi (as said) transistor bought new, because transistor 2SC2312 were changed... he thought!
But latest informations given to us allowed a new departure: Mitsubishi 2SC2312 were falsificated by Chineese (fake ones) and so we could determine with pictures of fake that Richard bought fake ones... so it could be the explanation why the amplifier was no more working. J-L naudin and me wo ordered new GUENINE transistors, and he first obtained a new working negative power system operational, and me too.
Without this amplifier we had real overunity, but not enough to compensate amplifier losses (all measurements made up to now). With these transistors we have a negative power, compensating amplifier losses and a complete overunity system. So there is no more trouble to make a new loop now. These transistors are the key: 2SC2312 and 2SC1969.
woopy
Woww!!
Very well done Pascal and JLN
magnifique resultat bravo à vous et à Richard Vialle
Following your work and immense motivation to replicate.
Good luck at all
Laurent
conradelektro
Quote from: Pascuser on October 24, 2012, 07:08:58 PM
@Pascuser:
Where did you buy the transistors 2SC2312 and 2SC1969? I could not find them at Farnell.
There is the transistor 2SC3263 (VCBO VCEO 230 V, IC 15A, 60 MHz, audio and general purpose), which costs EUR 3,72 at Farnell?
http://at.farnell.com/allegro-sanken/2sc3263/transistor-npn-to-3p/dp/1192129
I see that you used 7,2 MHz and 5,8 MHz in your replication. When using different frequencies, should not be there a different capacitor in parallel to the resistor? (Mr. Naudin uses C4 = 27pF in http://jnaudin.free.fr/rvproject/html/ugentest22.htm)
In the last photo of http://jnaudin.free.fr/rvproject/html/ugentest21.htm, Mr. Naudin also uses a capacitor (470pf + 500 pF variable) in parallel to the drive coil?
What is your opinion on the frequency (3.6 MHz, 7.2 MHz, 5.8 MHz) and the parallel capacitors (over the drive coil, and over the output resistor)? Your and Mr. Naudin's experience would be very valuable for future replicators. Are these capacitirs essential or can one compensate by changing the frequency?
I am very excited about your and Mr. Naudin's tests, this is what I was hoping for. Good documentation and good measurements.
Greetings, Conrad
Pascuser
There was an error in component specifications. Ceramic resistor used to measure output power was said non inductive by the vendor, but after a verification this afternoon (measurement with oscilloscope with the help of a real non inductive resistor) it WAS inductive.
So output power calculations are not good. I should have tested it before the experiment; I did it this afternoon. So the step is not yet passed. We stay on COP measurement (overunity output VS U input) with not yet the ability to compensate the powering system.  (not yet overunity output VS U input + amplifier powering losses)
Here messages about it:
http://www.conspirovniscience.com/forum/index.php?showtopic=922&view=findpost&p=24401
http://www.conspirovniscience.com/forum/index.php?showtopic=922&view=findpost&p=24408
So step will continue in what Richard VIALLE did (he never succeded in doing what we claimed with the ceramic, but succeded in overunity with negative power, it is the following step to have a loop); as engaged since 10 days.
woopy
OK
Thanks Pascuser for your honesty and quick rectification
so i am always very motivated to step in
so my begin in replication
hope this will encourage some of you to join the replication
good luck at all
Laurent
