Richard VIALLE's new theory about negative mass and overunity
Started by Pascuser, August 28, 2012, 07:03:17 PM
woopy
@Woppy
You had started to replicate in English, so I know you have some skills in English: wouldn't be a nice idea if you could complete the publication of your replication here? You have already all the materials for, I suppose, like pics and schematics ;)
Regards.
Hi Kwartz
Yes i did a replication of the Vialle U autogenerator. I include here a old video of my first attempt.
http://www.youtube.com/watch?v=mztzakUYoXw
My problem was that, at this time, i did not have a good enough signal generator to test different frequencies (around 3.6 MHz).
So i decided to replicate the Royer oscillator as per Jean Louis Naudin. And it work fine as per the first try.
But i realised very soon that the U gen is very sensitiv , and even a very small difference in the length of a wire could affect the results. And also probably each different copper tubing and the wrapping wire could need a different frequency and need a fine tuning at the input and output. So i got some crude results showing  me that the system is working as described.
The JLN Royer oscillator is a good demonstrator but  limited to the entry of  this fantastic  project. Than if you want to really go on,  you need  sofisticated material and knowledge and perseverance.
So i am now following the progress of the very good workers at Conspirovniscience, but i am no more directly activ in this field.
I am personnaly convinced that Richard Vialle is onto something , and i am happy that you try to enlarge the audience for this project. Bravo
Hope this help and good luck at all.
Laurent
tim123
Theory of the Autogenerator...
This page on JLN's website summarises Vialle's theory of the U-autogen, and it's ok in Chrome translate:
http://jnaudin.free.fr/rvproject/html/principervgen.htm
Quote...the conductor is subjected to a magnetic field, its scalar component will act on the electrons orbiting the core and deform its orbital radius creating an electrostatic field for attracting the electron by the core. The amplification factor of the oscillation toward and away from the core the electron is called "coefficient surespace". The larger it is, the greater the surunité...
tim123
Quote from: woopy on January 24, 2014, 08:50:39 AM
Thanks Woopy. Cool vids... I'll have to catch up with your LENR experiments soon.  :)
tim123
On the Pigtail... I've just watched the first 3 of Pascal's vids. In the third, they show the spinning disc experiments, and the pigtail.
When the pigtail is powered up, it's acting as an RF antenna. Probably quite a powerful one. It would be interesting to know what the range of it's signal is... 5 miles, 50 miles?
Anyhow, it clearly messes up the electronics in the digital scale, so it gives erroneous readings. So all the vid actually shows is that unshielded RF can screw up digital electronics, which is not much of a surprise...
So - has anyone recorded a weight change with the pigtail - using a set of mechanical scales? If so - is there a link / reference?
Tim
PS. Of course, Pascal's experiments showed a mechanical balance...
tim123
So have there been any developments in the last year or so - since the vids, and since JNL?
Are people still working on this in the french-speaking world? The forum links seem to end in February 2013...?
