Richard VIALLE's new theory about negative mass and overunity
Started by Pascuser, August 28, 2012, 07:03:17 PM
e2matrix
Quote from: tim123 on January 23, 2014, 01:45:05 PM
Hi Folks,
  I've just found this thread. Never heard of Richard Vialle before...
Has anyone proposed a mechanism / a principle of operation for the aUto-Generator? It's an interesting design...
I.e. how does the magnetic field cause the electrostatic effect? Is it simply the 'left-hand-rule'? Are the 2 halves of the U acting as halves of a dipole antenna?
I'm interested in finding out more about the 'Pigtail' device. From what I can tell - it has gravity modifying properties, and that's something i'd like to work more on...
Can anyone elaborate on the pigtail device? Pascal has this page, but it's not very easy to follow in Google Translate:
http://jnaudin.free.fr/rvproject/html/pascuser_rep4.htm
I notice that his resonance is at 155Mhz - which would be far too high for my test equipment. I would have to make a much bigger coil...
I wonder - is it possible / worthwhile - making a 3-layer pigtail coil...? (I have a theory about higher dimensions & spirals...)
i.e, something like this:
- Layer 1 - magnet wire wound on 16Amp house cable
- Layer 2 - result of above wound on 16Amp house cable
- Layer 3 - result of above wound on copper/plastic pipe
Regards, Tim
Were you using Google Chrome to translate that page ? or just copying it to Google translate page with another browser?   I find Google Chrome works best for doing translations of actual web pages.    Also I noticed the Baofeng UV-5R radio which if you are not familiar with is a Chinese made radio of excellent quality made somewhat for Ham Radio but they are great scanners and also can transmit outside the normal U.S. Ham bands (and yes they can do 151 or 155 MHz easily).   All this in a radio that can be had for around $40 (sometimes less) in U.S. dollars.   A few years back a radio with the capabilities of this one would have set you back $300 to $400.
tim123
Quote from: e2matrix on January 23, 2014, 11:44:11 PM
Hi E2M :)
  Chrome... I've just downloaded the PDF the page refers to - it's in French, but I can sort of get it.
That's a good tip about the radio - it's a bargain! Thanks. My oscilloscope only does up to 60Mhz though.
It seems that to add layers would be an obvious route for experimentation...? (Although wrapping the wire would be a bit of pain)
Khwartz
@e2matrix
Thanks for the rough translation from Google.
We could think indeed I would have translate the first pages of Pascal's first part report on the RAG but nope, it is Pascal himself while he started this thread. But he abandoned the project while not succeeding to get enough interest from the Community here to generate direct replications (Woppy is French tongue, as I can know...).
I could complete the translation of the two parts of this document but it is very technical indeed and for now I would prefer to focus on the simplest principles and very basics, directly applicable stuff for replication and improvement of the electronics.
I insist: For the Community in France, the system has already been proven working, so no need for now for unusual ideas but all at the opposite: to go further in the way already taken and known having already worked. What is needed is mostly a better electronics, an electronic of the level the engineer in electronics had worked out and obtaineed perpetual charging batteries at the input (!) in addition of a load at the output.
Regards.
@All you guys of Conspirovniscience.com
Please, if you see any error in what I report here or you can complete, feel free to do so!  :)
Bien amicalement, Didier.
tim123
Quote from: Khwartz on January 24, 2014, 06:08:32 AM
...the system has already been proven working...
Hi Khwartz,
  So the Pigtail is an autogenerator *and* it shows gravity effects too...
Can you give an outline of the most impressive results so far - i.e. what should an experimenter be aiming to replicate?
Is there a circuit diagram available for the reportedly OU version?
wings
Quote from: tim123 on January 24, 2014, 06:36:32 AM
Hi Khwartz,
some informations here
http://jnaudin.free.fr/rvproject/index.htm
http://www.magnetosynergie.com/forum/viewtopic.php?f=64&t=1475
