Richard VIALLE's new theory about negative mass and overunity
Started by Pascuser, August 28, 2012, 07:03:17 PM
Khwartz
Quote from: tim123 on February 25, 2014, 06:47:27 AM
Hi Khwartz,
  I don't know. It's a good question... Changing the tuning would decrease the magnetic field... It would be so useful to have my ZVS driver working - as it auto-tunes...
Wow! Selftuning :D looks like the wonderful "seltrigging system" of the Youtuber (still a French) Selfonlypath ;)
QuoteIf it does change the resonance - and the bulb then lights up at a different frequency - what would that mean I wonder?
Imo that capacitive coupling could interfere, especially stray capacitance, but it isn't necessarily "the Why" of the possible overunity, "the Why" of the phenomenon.
QuoteNo mate, it wasn't bad. I was just wondering if there was a way to cancel it out completely in the device itself - so I didn't have to try doing those calculations... ;)
OK, great to know my translation are compressible :p and nice to see you have a plan here :)
QuoteI could do the alu-foil shield - but i believe what Pascal said - and I'm not sure if it helps...?
Could be good you try for yourself! Don't think it is what it will take you the most time to do it, dear tim.
QuoteI was also wondering if perhaps the cap-coupling might interfere with the desired effect - i mean - it's supposed to work because of the magnetic field - but maybe the electrostatic field is interfering with it... Just a thought.
Better to verpies to answer you that point :/ and/or check by yourself.
QuoteThe best idea i can think of so far - but it's not perfect - is the 2-layer counterwound coil - fed with balanced + & - signals... That way the 2 counterwound coils would make the same magnetic field - but the electrostatic field would (more or less) cancel out.
If you say so, I am OK to believe you, tim, cause I don't know so much about coils ;)
QuoteMaybe it would be possible with a normal bifilar coil...?
But verpies' additive one! :p
QuoteRegards, Tim
Best regards,  K.
Khwartz
@ ATOMMIX
Care to show your objective results (like your saucer you will oviously finish very soon as sure as your are in your statements) and then we will care objectively of your objections...  ::)
tagor
Quote from: Atommix on February 26, 2014, 03:09:09 AM
I have been trying to up load attachments here there seems to be a block on them ?
ATOMMIX
can you send me your documents and I post them here ?
