TPU secret (steven mark)
Started by dreamyear, August 30, 2012, 06:13:56 AM
dreamyear
Bruce_TPU
 Steven Mark said that magnets are not needed for tpu operation.  Study the interactions betweenmagnets and intermodulation products.
Cheers,
Bruce
dreamyear
Quote from: Bruce_TPU on August 30, 2012, 09:49:08 AM
Cheers,
Bruce
I would say that too....if i want to hide billion dollar secret  from someone else.......
ionizer
NO!
It's all bullshit.
The google streetview car drove by that demo mansion a second time and it made even better pictures then before, revealing the true source of power!
Bruce_TPU
Quote from: ionizer on August 30, 2012, 10:22:47 AM
NO!
It's all bullshit.
LOL,  I guess the engineer reports by REAL engineers, tested at THEIR facilities, and those engineers were all duped... Like I said... LOL
P.S.  All of the engineering reports are in the public domain.
Cheers,
Bruce
