Free energy generating coil.
Started by synchro1, September 10, 2012, 10:32:48 AM
gadgetmall
Quote from: synchro1 on September 12, 2012, 10:47:58 AM
Here's a video of a stationary free energy generating coil that really works:
http://www.youtube.com/watch?v=9XMfCpUzq_g&;list=UUGj-eKaG5_tMGNr_yuLePkA&;index=6&;feature=plcp3
Nice Job Synchro1 . Now this is a real energy harvester . Some even call it Zero -point energy.but it's called Tunneling-Effect Energy Converters. Nothing new though but Very real . Some of us have  seen experiments using diodes as energy harvesters and yours is a perfect example of a large coil to collect the millions of electromagnet waves produced by man and by nature tunneled with a  diode{germanium works better) and stored in a capacitor .If you can pick up a radio station that is enough energy along with thermonics. There was something similar years ago that used just aluminum foil capacitor and a flash unit from a camera . it would gather enough electricity and fire off the flash from the Negative potential of the earth ground to the positive potential in the air collected by the foil and stored in a cap ...
Anyways  Nice Build and this one is not fake and worthy of study . We know that Syncro1 and thanks for sharing . I have also seen the damage a one inch neo ball magnet can do playing with the Bedeni no bearing motor one shot in my wall at the other house.If it hits you in the Head your are probably Dead.
If you want a better explanation of it lots of people here know about diode energy . and here is a very good explanation
http://www.youtube.com/watch?v=JcCLIwlbhLc&;feature=related
More scientific data :
http://www.integrityresearchinstitute.org/ZPDiodeProjectSummary.htm
        DARPA: Energy Harvesting Using Rectennas  www.coolcadelectronics.com/DARPA_Energy_Harvesting.html We propose to help solve the energy crisis by directly harvesting energy from  the use of micro-antennas coupled to rectifying diodes and storage capacitors.
e2matrix
http://www.youtube.com/watch?v=9XMfCpUzq_g&list=UUGj-eKaG5_tMGNr_yuLePkA&index=6&feature=plcp3
Thanks for that one synchro1 and gadgetmall - does anyone know exactly how that is wired up?  I ask because I've got a huge spool of that exact same 4 wire stuff as seen in that video that's about 10 inches in diameter.  I was even thinking some bifilar or quadfilar hookup when I picked it up at a garage sale :)   I've got the Schottky's and caps but just would be interested if anyone can suggest best way to wire it up.
gadgetmall
He probably has it in series . just put all your 4 wires in series like one long wire with the diode and cap .
here is the summery of that process .
This executive summary addresses the basic built-in voltage potential for all semiconductor p-n junctions and various rectifying devices suitable for generating DC electricity at “zero bias” (with no bias DC voltage applied whatsoever). Tunnel diodes are one class of rectifiers that are qualified. Even microwave diodes are good choices since many are designed for zero bias operation (see below). Reference articles are attached in the Appendix showing the use of “broadband spiral antennas” and phase conjugate mirrors for amplifying electromagnetic frequencies that make up quantum noise. The tunneling current in the diodes can also be influenced by the use of magnetic fields as low as 10 gauss as well. The recent discovery of a “Brownian Refrigerator” or “the world’s smallest fridge” that “rectifies thermal energy” accentuates the additional spin-off from the ZPE Diode Project:
Quote from: e2matrix on September 12, 2012, 02:08:16 PM
You might try something like this. Experiment with different smallish caps across the coil where I have the variable symbol, and a much larger capacity but lower voltage storage cap across the output. If you also put an aerial antenna to the "top" of the coil it might work even better depending on the frequency of the power you are harvesting.
synchro1
@Gadgetmall,
                       Thanks for those DARPA hyperlinks!
@e2matrix,
                       The wireing is identical to the Danial McFarland Cook battery patent. This patent and attached wireing schematic predate the incandescent light bulb.
                        It helps to place a 1" neo magnet sphere inside the air core of the 4 wire coil and shake it up a few times to help charge the tiny high voltage capacitor to start it up, then the sphere magnet can be removed and the charge continues to build spontaneously.
