0 Members and 94 Guests are viewing this topic.
itsu
Quote from: DR.WHO on April 27, 2016, 10:48:15 PM
Message for Itsu !
Your a good engineer clean tidy and professional and I enjoy your videos ! But I am confused as to what is driving you to do all there replications and not what I can fill is your real goal and to invent your own technology ?
Are you having trouble with free energy self running set ups or are you just happy doing replica builds ? I have never found one that can truly be built to a stranded that is presented in the drawings and data ..
There is a lot of negative and positive people here all are mostly just tinkering around or just pretending to know what they are doing but you have something very special you are real !
Please tel me what is it that you really want to build or discover .. I tend to go for 10kw and above and have isolated many effects known and unknown and I like to study quantum effects in EMF and the Doppler shift as a quantum field drive in zero point energy .
Micro circuits or nano pulse is some what on the small end of things and life is a lot easier on the larger side and quite often cheaper to ! Formula is the foundation and if it can not work there it wont work in the build. Experimentation with hard wear is time consuming and ohms law is nerve going to help with reactive circuits ! Try this try that approach is not formula and formula can be a language that you understand .
What is it that you want out of all this work ?
Hi Dr.Who,
thanks, i just replicate things and i am happy with that, i lack the skills/talents to "invent your own technology".
I try to confirm what is being presented by these self runners by replicating them as good as i understand them but with
a lot of help from the guys on these forums.
Hopefully someone will put the pieces of the puzzle together and if i can contribute a small piece to that it will be my pleasure.
Together with verpies (and others) we did extensive research on this Dally nano-pulser and it would be a waste if we did not explore it further
if it could be used in this Ruslan setup or like Lost_bro mentioned in the *Chinese D.S. replication*.
Itsu
NickZ
  Here is what wikipedia mentions about Radiant Energy:
https://en.wikipedia.org/wiki/Radiant_energy
  Itsu: I was wondering what you were up to.  When you're quiet here on the forum, your hands are always busy.
  Thanks for the video,  and good luck with that circuit.
   I'm still having problems finding a transistor that will oscillate now (burnt my last good one), when making an Exciter/Kacher circuit.  I tried a fet, also, same thing, won't oscillate. Anyway, I'm taking a small 15inch Tv apart today, to see if I can scrounge some parts from it.
  I'd like to make a strong Exciter circuit but one that won't overheat the transistor. Ha!  As I'm always having the Kacher transistors getting way tooooo hot. And I don't want to use a fan, so, I'm thinking about Exciter circuits, like Nelsons, but maybe taking the idea and modifying it in my own way. I wouldn't want to just copy it...  As I can't, in any case.
   So, I'm still on the hunt for wild turkeys....  And, I haven't seen any down here, yet.
itsu
Schematic and a screenshot of the gate (blue) and collector (purple) signals when running 1.5KV @ 227V @ 15KHz
Guess i could use a 18V tvs on the gate.
Itsu
itsu
I added a 18V TVS from gate to ground; seems cleaner at the turnon now, but worse on the turnoff.
But the nano-pulse seems to be the same (amplitude/width), so this will be better for the IGBT gate i guess.
itsu
lost_bro
Quote from: Dog-One on April 28, 2016, 12:09:07 AM
Yes, not all diodes can react in less than 10 nanoseconds and clamp 1400 volts at 28 amps.  I hope Itsu gets it pretty close to correct on the first try.
Good day Dog-1
A decent choice would be the CREE SiC Schottky diodes.
'Zero reverse current' and essentially zero reverse recovery time (trr).
Maybe have to run two in series for 1.4-2KV protection.
Cree does make the 'double legged' diodes so those can be paralleled (on one device) for up to 40 amperes.
take care, peace
lost_bro
