0 Members and 147 Guests are viewing this topic.
TEKTRON
Quote from: NickZ on August 22, 2013, 10:45:30 PM
  Grum:
  I still have all the links to the Akula videos, but, that video has been removed, as you noticed.  I had also been looking for that video, recently, if that is the one which showed the wrench heating up in the toroid coil.   Well...So much for that...
Did anyone download that one from youtube?  I didn't.
I did ;) .http://www.2shared.com/video/24PvqQsJ/CE_akula0083.html
magpwr
Hi everyone,
Base on the attachment which i have pointed.Can anyone advise me if by using HV from flyback transformer to the thick coil as shown in diagram.
Would this thick coil will be acting like a induction heater if a metal is placed in it.My question is would the metal eg:screwdriver get hot like those that we see in induction coil.But only this time it's a HV but low current source.
Grumage base on your Kapanadze device if you were to put a screwdriver in it(no contact to device) would it get hot.Just curious.
Can anyone advise what could the yellow piece in circuit diagram represent.
Grumage
Quote from: TEKTRON on August 23, 2013, 01:16:10 AM
Dear TEKTRON.
I just can't open it. An "old fart" where computers are concerned!! :)
So my question is? Is this the video of heating the spanner? If so this is not the one I mean!! Around the time of that video there was another posted (Same Bench) with an array of Green Thyristors and a board with 3 red led's running in a sequence. This is what I am refering to with regard to the above schematic.
Dear magpwr.
The large Yellow tube is a Tesla secondary of 1000 turns of 0.25 wire on a 40 mm dia former. I am getting to know some Russian?? Please correct me if I am wrong?? :)
And no I have not tried to put anything metallic into the core. But if you cast your mind back I did have the center choke collapse. This could have been the result of the windings heating up from the drive coil!
Cheers Grum.
gyulasun
Quote from: magpwr on August 23, 2013, 04:55:50 AM
Hi magpwr,
The yellow piece must be a Tesla coil with 1000 turns of 0.25mm enameled copper wire and the coil holder (bobbin) OD=40mm
Greetings, Gyula
NickZ
  So Grum, the first thing may be to get something made of iron to heat up in the big air coil. And if it does not heat up, then, make a separate coil of thick copper wire, made to test the induction heater type output.
  Then the next thing is to get the big air coil's inner choke to help raise the voltage back up to 110- 220volts Ac or higher, but with lots of amps.  Easier said than done...
