0 Members and 447 Guests are viewing this topic.
Tomtech29
the use of mechanical wash relay ! but here it works and how it is possible such a short very fast pulse? :o
when tensions 120V. It provides the inverter able to weld the relay contacts?
for long period of time it will not work :-[
time 1:35   https://www.youtube.com/watch?v=4ZqHtsc537Y
Tomtech29
it's obvious that Ruslan has made changes to the structure of the coil itself said  ???
"coil has a different value inductive says it is building on the model of the transformer" ::)
NickZ
  Tomtech:
  Interesting, that last Ruslan video.  He is showing how the induction circuit lights the bulbs by itself, without the Kacher.
Each additional bulb added is dimming the brightness of all the previously lit bulbs, by quite a bit.
  He almost showed what I've been waiting for. To show how much more output the Kacher crt adds when connected to a full load 2000 - 4000 watts worth of bulbs. But he didn't, this time.  Bummer!
  Without the HV circuit connected his bulbs are lighting similar to how mine do, nothing special, considering his input voltage is twice as high as mine.
  I've modified my Kacher circuit to run on 24 volts now. And, I also have a new yoke wound up for 24 volts, as well. It runs similar to my previous yoke core, on 12v, but soon I'll connect it up to my Mazilli, which hopefully will be running on 24v also.
This might also help to keep the Mazilli's fets running cooler. We'll see about that...
  About 10 more days before my Techtronics scope gets delivered. So, I'm doing what I can until then.
Hoppy
Quote from: NickZ on July 27, 2015, 08:00:14 PM
  Tomtech:
I reached this point with my replication and had very similar waveforms. However, the Kacher only managed to add a little brightness to the bulbs or else dim them depending on tuning - the pulsating / flashing lamp effect. I don't recall seeing a modulated waveform from Ruslan showing the Kacher frequency. Can anyone show this ?
T-1000
Quote from: Tomtech29 on July 27, 2015, 06:06:14 PM
The main purpose of that video was to show how frequency shifts from different loads(from 27.154kHz without load to  29.12kHz with 3 light bulbs load) and how PLL keep resonant condition with spikes to control Tesla coil driver. Also the circuit had Tesla coil disconnected and was drawing 6A from 24V battery.
Also the relay switch there you just seen is used there most likely to power circuit after capacitor is charged and the button on top is pressed...
