0 Members and 446 Guests are viewing this topic.
Hoppy
Quote from: T-1000 on July 28, 2015, 04:09:03 AM
The main purpose of that video was to show how frequency shifts from different loads(from 27.154kHz without load to  29.12kHz with 3 light bulbs load) and how PLL keep resonant condition with spikes to control Tesla coil driver. Also the circuit had Tesla coil disconnected and was drawing 6A from 24V battery.
As Nick said earlier, its a shame that Ruslan did not show what happens when the Kacher is connected, both to the waveforms and the current draw.  :( The most important information is missing.
Dog-One
This part is still a little disconcerting for me.  If the frequency changes, then it's no longer in the 1 to 100 ratio.  Seems to me this would kill the effect we are after.  Have you found any more information that would explain the derivation of this ratio?  How it was found and what its actual purpose is?
Tomtech29
you are absolutely right relay is used to disconnect power supply
-I thought initially that uses it as a "IGBT" a primary coil.
I thought that because the transistor has been disconnected so it was obvious he was not at all Tesla coil arms ,
despite a power output of the system itself "LC" is another rule which I received on my core ferrite?
Sea somebody explain to me what it is due? (bulbs shine at such low load power source)
Tomtech29
NickZ
I wonder if your system will get better performance? or is the result of larger diameter ring volume is controlled or has a very big impact here
I found a uniform ring without connecting space of two halves
but is less fear that the winding 28 winding 4mm2 will be quite a challenge
induction heater would not look like we have a 810 watt load on the source 6Amp relatively need to take into account the voltage drop as can be seen in the light bulbs
AlienGrey
Why you call it induction heater, less heat and more electro 'static' RF it's a top band transmitter, put, if you want, to kill the Sun sling Iron ito it ! same here. Also mini signal relay, do you think it is switching two Kw ;) :) :) Bang !
