0 Members and 447 Guests are viewing this topic.
John.K1
T100 - I do not say you can't change magnetic properties. What I say is I think you can't change them quick enough. Not sure what this has to do with ruslan. More closer to his device is the principle of kirschov (or something like that) law, on which base two oposite curents create the kick at their meeting points. Just do what ruslan said and stop comming with such radecilous theory :)
John.K1
Who is native russian speaking here ? I need to know what ruslan said about the direction of the pick up coil and current coil in his last movie I posted here earlier. I had problem to understand if he said they both are wound in the same or opposite direction. I have such feeling he said they are opposite ?
Hoppy
Quote from: John.K1 on July 31, 2015, 05:49:51 AM
Common guys, you can't change temperature as fast to get any effect from it. That device looks to me bit a joke. Yes I am able to consider to use the temperature  to accelerate electrons, but to heat  wires or magnets in reasonable speed.....?  I think Roman just testing us ;)
Agreed!  However, high voltage, short nanosecond pulses can shatter ferrite but its doubtful whether this caused the damage to the ferrite core shown in the video. More like he used an already damaged and repaired pot-core for this device. The use of copper tape is interesting in that this is what some think may have been used by Kapanadze in his early box devices.
Acca
 It's the Akula secret in the last video...
https://www.youtube.com/watch?v=TLhtXQ7Wizo
https://www.youtube.com/watch?v=Noftcq8g7p8
https://www.youtube.com/watch?v=DeLvmi7v7T0
https://www.youtube.com/watch?v=l0sGJCabMTY
https://www.youtube.com/watch?v=V5iz4aZeQyc
https://www.youtube.com/watch?v=cG4fGxVlV7g
https://www.youtube.com/watch?v=FXDEAO9SfoE
Magnetostriction Magnetostriction is a phenomenon consisting in the fact that when magnetization of a body changes, its volume and linear dimensions change as well. Changing of the body shape can appear, for example, as tension, compression, volume change, which depends both on the acting magnetic field and the crystal structure of the body. The greatest changes in size tend to occur in strongly magnetic materials. During operation many electrical appliances produce noise. Noise of devices powered from household electrical outlet may be similar to buzzing or humming. It is caused by magnetostriction of cores in inductive structures, such as transformers or inductors. When alternating current flows through their coils an alternating magnetic field of the same frequency is created. It causes the ferromagnetic cores to shrink and stretch, which in turn transmit these vibrations to the air and other elements of the design. The magnetostriction phenomenon provides the effect of magnetostrictive transducers and relays, transmitters and receivers of ultrasound, filters and stabilizers in radio frequency devices. Magnetostriction is used to generate the ultrasonic and hypersonic sound. This phenomenon is virtually the only realistic method to generate hypersonic frequency of 1 MHz.
Here is the source ....
http://www.etrema.com/
http://cdn.intechopen.com/pdfs-wm/44683.pdf
http://www.alloy-cn.com/sell-terfenol_d_rare_earth_giant_magnetostrictive_alloy-2008474.html
http://machinedesign.com/news/designing-galfenol
Acca....[/font]
John.K1
Interesting. Just still donot know how is this applied in Ruslan's device :)
