0 Members and 447 Guests are viewing this topic.
Hoppy
AlienGrey
Now that Nelson has published his latest video on here, please notice on the bottom left a strange device that look's to be a cross between a BaCo foil winding and a transformer, any one any ideas what that might be ? It does appear to have a similarity to Vasmos device it's a nice device, lets just hope it sees the light of day, everything else seams to disappear once it's sold, such a pity.
Tomtech29
Quote from: Void on August 01, 2015, 10:10:54 AM
Hi Tomtech29.
K555TB9 (K555TV9):
Seems to be a type of JK flip flop.
https://commons.wikimedia.org/wiki/File:K555TV9_JK_Trigger.gif
Suppliers:
http://www.evita.lt/en/555tv9-k-mikroschema-k555tv9
http://www.russian-electronics.com/products/ics-unf-modules-microassemblies/:k555tv9
Thanks for the fix on the shop quickly and handily.
-something the next free day I will collect
I stand a little in one place with this circuit "LC" I had a few ideas to tune and match the capacity of capacitors, get smaller losses on the power supply. However, the problem remains the same: multi-layer coil output load 200 Wat -resistance is critical (as if close circuit on short circuit)We see the effect of the impact of a decrease in amperage so apparently supposed to work  :-\
except that either this coil is in the wrong direction and has a poor inductance and wire like copper but who knows it or not doped with other metals ,I swapped another ferrite with a slightly thinner cross-section of 3mm2 derivation from 3 turns I received a lower consumption of energy by push-pull (the effect of winding very close to each other) groan in no case power on the coil multilayer the question is why?
NickZ as you are able to light up 500 Watt power supply not enough that your system push-pull 12V how many amps goes to the inductor?
Please explain it to me what happens in your system when you do a short circuit at the output coil "168"?
-your red wire is stiff solid copper wire?
-or weave elastic cord 2.5mm2
at one case for real with older movies Ruslan hooked one bulb and the other on time and on an oscilloscope it was seen as the amplitude drops! and he says that resonance does not change and is in place and using the "pap" test signal from a small toroid.
and now 6 bulbs and says nothing about the amplitude seen as more bulbs lose their power until the battery very low power consumption ::)
I know I'm repeating myself but something I do not understand
-frequency load does not change and so resonance is and how it shows in his new film it is not necessary to use this small ferrite: toroid!
if we see that Kacher is disconnected "coil inductor 'I work in resonance and a few light bulbs Candle 50% of it and so does the rest of the work Piss little Kacher.
NickZ
  Tomtech:
  I don't fully understand what you are saying.  You asked me if what happens if the 168 turns coil is shorted at the output?
At the moment I can't tell you what happens, as far as consumption goes, because I have not trying to read the draw on anything yet. My scope will be here in about one week, and I'll be able to know more then.
  At least on my system, the bulbs have a lot to do with the way that the output behaves, as well as how different tuning caps affect the output. The amplitude readings do drop with each additional bulb added to the output. This normally normally affects the resonance values, as well. That's why the higher wattage bulbs are important to use, or the resonance factor due to impedence matching will not be available if using the small (25 to 60 watt) bulbs.
  Only Nelson's device uses the smaller incandescent bulbs, as it may work at a different mode of operation. Such as my Joule Ringer device works, and can light incandescent and CFL bulbs.
    I suspect what Nelson has is something like a Joule Ringer coil (coil under black tape), but, has also obtained a proper loop back to the input side, to allow it to self run.  I guess...  as this is a guessing game, with out it being fully disclosed.
  What he wanted to show us, was the possibilities, but not how it works...
   Nelson said, we should not be trying to obtain the highest output from the load, but rather be tuning for the best "effect".
This may be true, but, the way I see it, the best effect observed when tuning the device, will give the highest output at the bulbs, although the actual amplitude readings can be lower.
   Any way, the idea is to get this "effect", in the first place, that will allow the set up to self run, and light some bulbs, etz...
   Nelson, what happened is the video when "May Day" was said?  Did it go into a run-away condition?
nelsonrochaa
Quote from: magpwr on August 02, 2015, 04:33:58 AM
hi Nelson,
I am curious what the transformer which you used to obtain HV.Is it a high frequency audio transformer or high frequency voltage transformer at 27khz..
I can't help to notice that you used the transformer shield to connect to negative of capacitor in circuit board.
I am not familiar with driving a transformer using less than 10mA to obtain HV and output is a sinewave.....
Hi , the transformer is a ordinary 12v to 220v not any special note about that .  is a common transformer and is not working at 27khz it would burn insulation because 5 state of resonance chaotic mode .  but can be replaced for other type of coils like  grenade style  , you can go higher frequencies without the resonance problems but the tuning it will be more trick. Maybe people need to start with low values output circuits to have something to study and test , and after understand maybe is more easy make heavy units.
Yes the circuit run in less than 10 mA, i want to show to  compare with the actual drivers that people current use , and seems the ratio of output is poor compared with the input .
good luck
